Results 1 to 11 of 11
Thread: VP Sedan Custom Boot Ideas/Questions (Dual Fuel)
    VE Berlina
    Feb 2010
    Melbourne, VIC
    Default VP Sedan Custom Boot Ideas/Questions (Dual Fuel)
    Hello, I'm curious to know whether anyone has done a custom boot install on a VN-VS sedan with a gas tank in the boot? (I'm sure someone has..)
    I currently have a kicker setup consisting of a Kicker 2ch amp and 4ch amp, as well as 2 12" Kicker competition subs in a kicker box, as most of you would know having this and the gas tank in the boot doesn't leave much space at all, and restricts the spare wheel from being taken out.
    I'm thinking about doing a custom install with the subs/amps mounted to a false wall as far back as possible (without the use of a box), is is illegal to completely cover access to the gas tank?
    Any ideas/information would be greatly appreciated!
    VY Berlina V6 / R31 Skyline
    Dec 2008
    I'm not very sure about gas setups, but isn't here an emergency cut off switch or something? That needs to be accessible. Also, your subs need a box.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    OP doesn't know how to search obviously. Might be from 2009 but it's still relevant.
    Sub set up with lpg tank
    VE Berlina
    Feb 2010
    Melbourne, VIC
    Quote Originally Posted by sweefu View Post
    Yeah I figured my subs would need an enclosed box, it's possible to build a board around the cut off switch though, so that isn't a problem.
    Quote Originally Posted by wraith View Post
    Thanks again for another useless post wraith, but I'm actually after a VP custom boot setup, not a VT.
    Being a know-it-all yourself, you would know the boot layouts are quite different.
    VY S/II S Pack
    Apr 2011
    Contact this seller and organize a shipment of a left and right side boxes.
    If the kicker subs are square, #### them off and go with another option, don't be a brand fan boi.
    Build an amp rack around the gas tank, making sure that the emergency cut off is accessible.
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by Pickled View Post
    You still get ideas from it. If you're going to be aggressive then we don't want you here. Have an open mind and be willing to take advice, rather than having your mind made up already.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Are you retarded. OK save you reading I will spell it out. You can have a custom boot install. Everything bar the access panel for the gas tank can be covered.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    YES! Youuu are correct!!!!!!
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VE Berlina
    Feb 2010
    Melbourne, VIC
    Quote Originally Posted by MAG00 View Post
    Where do the left hand boxes sit? No I don't have the square subs.
    I'm very open-minded but have no time for smart asses like wraith, I appreciate all the help I get from this site.
    I read the entire thread, I'm aware I can have a custom boot install thanks.
    The purpose of this thread was so that I could see other user's custom boot setups with gas tanks.
    Now, back to business..
    What's the best materials to use for a setup like this? MDF? Fibreglass? What differences in sound will there be?
    VY S/II S Pack
    Apr 2011
    I assume they sit in the same spot on the left hand side..
    Use MDF, unless you want to really save space and get into tight spots.
    VE Berlina
    Feb 2010
    Melbourne, VIC
    The spare wheel is on the left hand side though? Unless they only make the left sides for VT upwards..
    Looks like MDF it is then, thanks for your help mate.
  1. Replies: 15
    Last Post: 07-08-2011, 01:40 AM
  2. custom boot advice/help/ideas
    By vsowner94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2011, 08:12 PM
  3. Dual Fuel Questions
    By VEOmega01 in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-02-2011, 08:20 PM
  4. Custom boot ideas...
    By vl-sl-commodore in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-02-2010, 12:08 PM
  5. VH 253 dual fuel running VERY poorly..ideas?
    By Rzeractor in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-04-2007, 10:02 PM
