Hi,
I have a VTII Berlina with the adjustable power antenna, the factory head unit had a switch that you could use to set it to any height you want.
That antenna has now died, if I buy a new one from Autobarn or supercheap, will I still be able to use the adjustment switch?
Cheers,
Tim
When you say the 'antenna died' do you mean the motor no longer works..? You can just replace the mast itself.
Lets work as a TEAM and do it MY WAY!!
if its hooked up 2 the factory wiring then theres no reason y it shouldnt work via the head unit.
