Results 1 to 14 of 14
Thread: Upgrading sound but keaping factory head unit vx
    VX Clubsport R8
    Oct 2011
    Collie W.A.
    Default Upgrading sound but keaping factory head unit vx
    Hi guys, I'm in the process of upgrading my sound system but I'm keeping the original head unit, too much stuffing around with steering wheel controls and it looks better "un-touched". I dont know anything about electronics or audio systems but I've done a fair bit of research in the last couple of months and came up with this solution - see attachment ( if Iv'e uploaded it right )
    I'm going to get an auto sparky to do the power cables and fuses but the rest myself. Still choosing amp and stuff but I think I'm going for Rockford Fosgate amp and speakers.
    Let me know what you guys think please
    Attached Thumbnails Attached Thumbnails Upgrading sound but keaping factory head unit vx-car-audio.jpg
    VY S/II S Pack
    Apr 2011
    What do you want to achieve from the system?
    What is your budget?
    Do you really need rear speakers? Rear speakers ruin your front sound stage and unless you have frequent rear passengers they aren't worth it.
    Other than that, your wiring seems ok from a brief look.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    somthing 2 think about also if u wanna do away with the speaker to RCA convertors u could contact Greg (pheddy from ASR) he can convert ur head unit so it has 2 pairs of RCA's pre outs, aswell as an 3.5mm auxilary socket as an added feature.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VX Clubsport R8
    Oct 2011
    Collie W.A.
    Not really using a budget as such but its true what you say about rear speakers though. The problem is that I do have a few passengers on a regular basis. The goal is good bass and good quality sound that will rattle the windows a bit
    VX Clubsport R8
    Oct 2011
    Collie W.A.
    Quote Originally Posted by wrx884 View Post
    I never even knew that was possible, that's awesome! How can I get in touch with Greg from ASR?
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    This is their sub forum here - ASR Audio & Electronics
    This is their website for a bit more info - Welcome to ASR Audio & Electronics Home Page
    Your diagram is okay, but from what i can see you only have 1 line out convertor, and a 5 ch amp. You may need to use more line out convertors if you plan on running multiple amps, or if you want to provide extra inputs for a multi channel amp.
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Diagram looks ok, however I would use accessory wire rather than ignition wire to turn the amp on. The accessory wire is yellow and is located at the mobile phone plug which is a 4 pin plug in behind the passenger side console panel (Will need to remove glovebox). You can even use a male spade terminal if you really dont want to cut or alter the factory wiring (Providing the plug has not been cut off).
    Hope this helps.
    Simon
    Lets work as a TEAM and do it MY WAY!!
    VY S/II S Pack
    Apr 2011
    In regards to your diagram you also have the main power line connected to the negative terminal, when it should be connected to the positive.
    wrx884's Avatar
    Mar 2006
    i should have mentioned b4 Gregs conversion also comes with a remote wire so no need 2 hook up 2 the ignition or ACC 2 turn on ur amps.
    VX Clubsport R8
    Oct 2011
    Collie W.A.
    Quote Originally Posted by VQXTC View Post
    Hope this helps.
    Simon
    That does help heaps, I've been trying to figure out a way to do it without using the ignition this whole time. I'm gona go and see if I can find that wire - cheers mate
    VX Clubsport R8
    Oct 2011
    Collie W.A.
    Quote Originally Posted by MAG00 View Post
    Thanx, I will revise my diagram
    VX Clubsport R8
    Oct 2011
    Collie W.A.
    Having a hard time getting the new speaker wire threaded into the doors, any ideas?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Pull the loom from between the door and the cabin off, thread it through the hole in the cabin, through the loom, then into the door, then put the loom back into the door/cabin. Much easier.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VX Clubsport R8
    Oct 2011
    Collie W.A.
    Quote Originally Posted by sweefu View Post
    Great idea! cheers mate
  1. factory head unit
    By Macka21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-09-2011, 03:31 PM
  2. Replies: 15
    Last Post: 27-11-2009, 04:18 PM
  3. removing factory wh head unit.
    By 02DUBH in forum General
    Last Post: 14-01-2009, 02:04 AM
  4. Need help removing factory VZ head unit
    By Explosions Hurt in forum Car Audio
    Last Post: 02-07-2008, 06:25 PM
  5. Upgrading Calais Head Unit with Steering Wheel buttons
    By hingo1983 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2006, 08:39 PM
