Guys,
Would I notice a big difference in quality if I just replaced all the standard speakers in the SSV? I.e. focal all round with 2 x 8" subs?
Thinking of running off the standard system, disconnecting the centre speaker and running the existing amp?
What do you guys suggest? What are the speaker sizes again?
Thanks all![]()
In short, yes you would notice a big difference in sound quality.
As for suggestions, how much money are you looking to spend roughly? Will you install or will install need to be included in the cost?
Cheers.
Not sure mate, maybe max $1500? Inc install...
i will have my speakers replaced tomorrow in a new VE with focals. No sub though. $860 installed. Can report back after.
Is your amp being upgraded too?
A mate gave some advice to me about installing something.
Basically it's a Fusion 450watt sub/amp box. I didn't want to spend heaps and he said it was about $250-$290. He said this was a simple hook up and a cheap one.
Well, imagine my surprise when I get home on Saturday to a bunch of junk mail including a Supercheap catalogue. The best bit was 35% off fusion. So I burn down to the local and surprise surprise they have the one he was talking about... $194. Done. Will install some time this week and let you know
Sent from my iPhone using Tapatalk
Cheers bonners - how will that work with the existing subs?
It will sound clearer but you'll probably lose the bass from the speakers so it won't sound as loud as before. The stock speakers are used because they suit the doors, power and EQ of the standard head unit perfectly. Aftermarket speakers require more power and low frequencies will be the part that suffers.
Hmmmm ... So how would I counter that mate?
I'm not installing amp. Just new speakers. If you get the right speakers which are suitable without an amp, I'm told it will still sound heaps better. Amp isn't mandatory for a low-end upgrade.
Druery are working on my car now; just dropped her off.
I upgraded my stock speakers and the sound wasn't much better. I even used 2ohm to keep it all the same. Now that I've added 2 amps and a sub it's a massive difference. I also had the RCA mod done by Phreddy![]()
More power (an amp) will make everything louder including the low frequencies.
Better sealing of the door cavity will improve the low frequency performance of the speakers. Deadening the doors involves sealing the interior access holes which reduce the low frequency response of speakers.
But both of those add costs.
My system installed now, was Focal PC165 in the rear (2-ways) and PS165 in the front (splits or "co-axial"). These are award winning, but entry-level for a particularly good brand.
Like I said, $870 installed. Probably take a novice four hours to install it yourself, but someone experience takes about two probably. I paid them.
No amp.
They also disabled the centre-mounted dash speaker because it sounds crap leaving it on. Satnav voice-over comes from my front-right speaker.
So how's it sound?
I have a pretty good ear. I can clearly hear the difference in treble, it's a very big improvement. Midrange I can't pick it. Bass is much more defined too. Overall sound quality is markedly better, more crisp, better definition, and not muddy anymore.
It is no louder, though, you need an amp for that.
But I'm really happy. It's just what I wanted.
The installers, Druery in Dee Why, said it really needed an amp to get the most out of the speakers (and they're right), but that doesn't mean they are required for the sound to have improved. If I'd spent another say $600 for a quality amp, it'd be much louder and the bass even richer. You can just keep spending money on audio, like anything.
Thanks mate - so if i copy that setup but maybe add an amp i should be good... did you change the subs?
How much did it set you back? (install and parts?) PM if u want.
Were the speakers a straight swap or was modifications needed? Got any pics?
I'm not after LOUD .. more clarifty and something you can feel in your chest while in the car not outside!
Thanks mate
If doing a decent install, there will need to be some modification to the inside of the doors, some treatment from dynamat, new baffle for the speaker etc. All of these things make a huge difference, more so than the choice of speaker. Not a modification as such, but I would be prepared to spend a bit of time on the install (or money if having it installed). Install accounts for more SQ than the choice of speakers.
^ Sweefu has won Sound Quality awards with entry level gear installed fantastically, listen to the man >.<
I have wagon; so no subs to replace. Price in earlier post $870.
If you had amp and subs, it'd be lively and a whole next level of audio to mine. Sedan have the parcel shelf too. it looks completely stock, you cant tell visually there are new speakers behind the trim.
I dont think dynamat was installed. I didn't know to ask or suggest. Maybe my system with no amp would not need it.
Mine can be upgraded by installing amp in the future if I wanted. It's possibility.
I don't know what "new baffles" are that Sweefu mentioned.
Hope that helps!
