Hi I have jut installed a full system into my thunder ute, have had a small bit of trouble with wiring and amps but have now got wiring etc spot on, however I have lost all sound out the right channel, nothing at all straight out the headunit. I've tested everything and I have even hooked a single speaker straight direct out of the right channel to test and have absolutely nothing.. Does anyone know what the problem might be is it possible to blow internal fuses on individual channels in the headunit? Pretty stressed out that I may have damaged the IQ...any help is much appreciated
