Page 1 of 3 123 LastLast
Results 1 to 25 of 66
Like Tree4Likes
Thread: help nic design a new sub box
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    Default help nic design a new sub box
    hey guys
    so i am thinking about buidling a new box for my sub
    the box i have now is a bit small (3.8cf after port/sub displacement) but it does sound ok. i was looking at getting a bit more out of my subwoofer if you know what i mean.
    anyway my friend helped me design a box to fit in my boot and im not sure if it will fit sliding in, i might make it up out of cardboard and see how it fits.
    i just want to know what you guys think or have any recommendations or tips?
    so anyway the pictures with the dimensions is in attachments (It's somewhere around 6.5cuft@32hz, give or take a little)
    here are the sub specs
    Enclosure Recommendations:
    Compact Optimal
    Sealed: Not Recommended
    Ported: 5.5@25Hz, 8.0@34Hz
    Dimensions:
    Mounting Depth: 9.4 inch
    Mounting Hole Diameter: 17.75 inch
    Overall Diameter: 18.5 inch
    Bolt Hole Circle: 17.5 inch
    Motor Width: 6.5 inch
    Motor Depth: 3.25 inch
    Basket Depth: 6.25 inch
    Displacement: 0.22 cubic ft.
    Weight: 28 lbs (12.7 kg)
    T/S Parameters:
    Electrical Q Value (Qes): 0.53
    Mechanical Q Value (Qms): 6.1
    Total Speaker Q Value (Qts): 0.48
    Free Air Resonance (Fs): 33.2 Hz
    Equivalent Compliance (Vas): 159 liters
    One-Way, Linear Excursion (Xmax): 22 mm
    Efficiency (SPL 1W/wm): 92.7 dB SPL
    Effective Piston Area (Sd): 1210cm^2
    DC Resistance (Re): 1.9 ohm
    Nominal Impedance (Znom): Dual 2 or 4 ohm
    Thermal Power Handling (Pe): 1000 W
    Force Factor (Bl): 21
    Attached Thumbnails Attached Thumbnails help nic design a new sub box-6.5cuft-32hz1.jpg   help nic design a new sub box-6.5cuft-32hz2.jpg   help nic design a new sub box-6.5cuft-32hz3.jpg
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Are you looking for more volume (Higher SPL at a comp, high dB reading) or nicer bass to listen to? These things are fairly opposite, your bass will be louder around 40 - 50hz but this will sound pretty rubbish if you are listening to music, something lower like 32 or 35hz will sound good to listen to but will not be as loud on the termlab.
    What I have said above is very general and broad statement but it more or less applies to what you are considering here.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by sweefu View Post
    im not sure yet, i will talk to my friend about it, but either way the box needs to be bigger. so that is my main concern at the moment. and then lets talk about tuning after i know for sure the box is going to fit into the boot.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    so look at my dodgey atempt of making it out of cardboard to see if it fits. i did the whole height as 40cm because i just didnt bother with the little bit at the top which was 20cm depth, the box went in about half way and got stuck but it wasnt 35cm high. so i rekon it would be pretty close. but it was the wrong way around lol silly me, so when i tried it, the 70cm was at the front and 80cm was on the side. i rekon it would just fit going in even if the sub (cone) gets pushed down as it goes in.
    what are your thoughts?
    Attached Thumbnails Attached Thumbnails help nic design a new sub box-141120113614.jpg   help nic design a new sub box-141120113619.jpg   help nic design a new sub box-141120113622.jpg
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    so after having another look the box can go about 4cm wider and it will add about another .4cf so my friend is going to re do the design and it is going to get tuned low (well it is a daily setup). il post up pics when i get the sketch ups. anyway its going to be good because its going to add an extra 3cf to the volume from the old box.
    it would also be nice if ppl would show some input
    VY S/II S Pack
    Apr 2011
    Are you sure it will fit without damaging the sub? Have you left enough room for the movement of the sub?
    Dec 2008
    This is a good point, your xmax seems to be 22mm at full bang, so you technically need 11mm room, but I'd want minimum 50mm to be safe, while taking it in and out etc
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    there was about 11cm (measured it from the outside rubber bit on the sub to the boot light) for excursion with the old box and this one is only 2cm higher, i left heaps of room just to be safe
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    my friend finally got back to me and said
    ‎7cuft@31.3hz so it'll work out to about 6.9@32hz with the sub in. Is the the tune you want? Theoretically going from 32hz tune to a 35hz tune gives a peak of 2db higher around 40hz. Or Tuning 37hz gives a 3ish db gain around the same area. Upto to you though. The 32hz tune has a dead flat response down to 35hz where as the other 2 peak @40hz like I said.
    now i just need to decide
    VY S/II S Pack
    Apr 2011
    If you want sound quality, aim for dead flat. If you want loud beats, go for a peaked response.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    yeah man im going for the 32hz tune, since im not really going for a spl setup, its mainly for daily so as soon as i get the sketch up pics of the final design, il post up
    VY S/II S Pack
    Apr 2011
  15. #15
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  16. #16
    VY S/II S Pack
    Apr 2011
    Have you taken the volume displacement of the added thickness and bracing into account of the internal volume?
  17. #17
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    friend designed it all and told me to do it that way ^ so im guessing yes he did, i get the sketch up tomorro and il show ya how it will be.
    since my old box was a bit of a fail with no bracing or anything
  18. #18
    Dec 2008
    If it were me I would be going with something thicker than 25mm, even though you have bracing for a sub of this size it will be pushing a lot of air, I would go something a little bit thicker. Are you going to seal the inside with polyester resin? Will only cost maybe $15 for 1kg which would do a great job of sealing everything. Be sure to put the box together with MDF glue also or proper wood glue (Selley's aquadhere) Not Liquid nails or any construction adhesive, the MDF glue soaks into the MDF making a very strong join, rather than the Liquid nails which just sits on top of the MDF
  19. #19
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    yeah but last time i wanted thicker wood like 1inch for example, they had to order it in and would cost like $100 for postage or something. unless theres another place to buy wood from? other than bunnings hehe, also thicker wood, would take up more boot space/volume, if i were to use thicker wood, i guess i could just fit it in the boot.
    what if i get half an inch wood and seal 2 peices of wood together to get 1inch thick for the whole box?
    i have never heard of polyester resin and since it will cost under $20 i might aswell do it
    thanks for the glue tip
  20. #20
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    i finally have the final design here, so it ended up as 6.9cuft@31.5hz and after displacement it is around 6.8cuft and tuning is just under 32hz
    so watcha think?
    Attached Thumbnails Attached Thumbnails help nic design a new sub box-6.8cf-32hz.jpg   help nic design a new sub box-6.8cf-32hz-2.jpg   help nic design a new sub box-6.8cf-32hz-3.jpg
  21. #21
    Holden VZ Acclaim Odyssey Blue
    Aug 2011
    use thick wood maybe MDF and make sure it is stuck right so theres no vibration make sure its custom to fit ur boot so u can fit anything else in there instead of having a box in the middle of you boot and fit nothing in there
  22. #22
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    If your serious about bracing i would be looking to do more than just adding ribs.
  23. #23
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  24. #24
    Dec 2008
    Bunnings should have something decently thick. Which side of WA are you on? I'll take to some friends and see who stocks decent MDF.
  25. #25
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    yeah umm Perth
  1. Vn Bt1 By Design, vn bt1 by design specs
    By 77lxhatch in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-06-2011, 10:07 PM
  2. Sub Box Design
    By HoldenCVZ in forum Car Audio
    Last Post: 08-08-2010, 04:13 PM
  3. need a design
    By COO1VS in forum General
    Last Post: 05-05-2007, 05:01 PM
  4. Rim Design??? help me out...
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2006, 12:07 AM
  5. Sub Box design???
    By Cameron in forum Car Audio
    Last Post: 07-10-2005, 09:18 AM
