Results 1 to 10 of 10
Thread: Subwoofer Wiring Inside Box
    VE SV6 SERIES 2
    Jun 2011
    Kearns
    Default Subwoofer Wiring Inside Box
    Hi all,
    So, I'm scared that this is a really dumb question when it comes to wiring up my new sub inside the sealed box. I ended up purchasing a Rockford P2D4-12 sub and installed it yesterday but just want to make sure I'm right here. It is 4ohm DVC so I have wired it up in Parallel to create 2ohm at the amp.
    My question is how is the best way to wire it up out of these scenarios or does it not matter.
    First scenario:- run positive to first + on the sub then piggyback to the next + terminal of the sub, repeat for - terminals (this is how I have it now).
    Second scenario:- run 2 seperate wires from the + terminal board of the sub box to each of the + terminals of the subwoofer, repeat for - terminals...
    or does it not matter which way it is done??? Technically this is the same outcome yeah?
    Cheers,
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Doesn't matter which way it is done, electrically it's the same. I don't usually piggyback as I can't fit two lots of wire into the one terminal.
    VE SV6 SERIES 2
    Jun 2011
    Kearns
    Quote Originally Posted by StoneX View Post
    I was going to add that that was the only problem I could see by the way I did it. Maybe I'll go the other way about it just for that reason.
    Thanks
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Obviously that still works but you have a bunch of unnecessary joins which seem like twist and tape jobs... You're much better soldering the wires and heatshrinking, but tape is fine if done properly. What's with the un-taped connections inside the box though???
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    they are soldered and of course i taped them up, i took that picture ages ago for a build log
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It's all the same shit, that way is just harder because you need to squeeze two wires into the terminals.
    VY SS
    Jun 2006
    Albany
    buy an amp with 4 terminals instead of 2 lol
  1. Help With Subwoofer And Amp Wiring
    By Tw1n Tur6o in forum Car Audio
    Last Post: 10-12-2009, 06:59 PM
  2. Subwoofer Wiring Wizard
    By Joe Bellissimo in forum Car Audio
    Last Post: 07-12-2009, 03:48 PM
  3. 2 ohm wiring for pioneer subwoofer
    By r_i_d_a_h in forum Car Audio
    Last Post: 12-02-2009, 07:19 PM
  4. Subwoofer wiring in VE sv6
    By EnFoRcEr_001 in forum Car Audio
    Last Post: 16-12-2008, 08:52 AM
  5. Wiring Subwoofer to Amp
    By tr3nt in forum Car Audio
    Last Post: 31-12-2006, 08:48 PM
