Hi,
I have currently have 2 x Kicker Comps (10DC122) 150rms, each sub has 4ohm impedance.
I want to add in another 2 comp subs. My amp is rated for 600rms at 2ohm.
If I wired my current 2 subs to 8ohm in series then added an additional 8ohm sub and 4ohm sub all in parallel would this give me 2ohms back at the amp?
(4+4)Ω::::8Ω::::4Ω::::::2Ω amp?
Is it stable to run subs with different impedance?
No, you cannot use different impedance subs together has the lower impedance subs draw more power. You also should not run speakers in series.
You cannot get a 2 ohm load to that amp with four 4 ohm subs, you need four 2 ohm subs or four 8 ohm subs.
Oh ok, So this wouldn't work?
Did you even read what he said. It will not work!
hell no!
maybe if all the subs were in separate enclosures... in different carslol
A mate of mine used to run his dual 2 ohm type X sub coils in series so he'd have a 4 ohm load - nothing blew up or caught on fire even after 2 years.
You should have Googled it, like I recommended. I tried to help but now you've made yourself look stupid. Here's the info you should have found.
Originally Posted by http://www.diyaudioandvideo.com/FAQ/Wiring/
Originally Posted by http://mobile.jlaudio.com/support_pages.php?page_id=163
So I have a question. I have two identical amps that have a bridging function that allows the two amps to create a single 4-ohm load. I also have two identical sub in identical boxes, they are DVC 4-ohm 12" L7s. I have them wired in parallel in the boxes to create 2-ohms, and then in the two boxes in series to create the single 4-ohm load, is this bad?
I currently only have 1 amp and 1 sub in the car so I can have some boot space, but if I want to show off or go to a comp I will put all the gear back in.
Ronald Reagan (1986)
Next time take the advice to Google it before arguing back then
It's simple, don't wire speakers in series. Wire the coils in series so each speaker is 8 ohm overall and then wire the speakers in parallel to create your final 4 ohm load.
