Results 1 to 12 of 12
Like Tree5Likes
  • 3 Post By HCVP
  • 1 Post By HCVP
  • 1 Post By MAG00
Thread: amp for 2 x JBL GT5-15's
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    Default amp for 2 x JBL GT5-15's
    Hi,
    I want to buy 2 x JBL GT5-15 subs. Each sub can handle 300rms and 1200watt peak.
    My amp puts out 600rms and 1200watt peak (Pioneer GMD8500M). Will it be enough to power these subs?
    Subs\
    My amp
    Thank you.
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    Now I have an absolute noob question. If a monoblock amp that is rated at 300wrms @4ohm is hooked up to two subs rated at 300wrms @4ohm.
    Will each sub get 150wrms? I am so sorry for this question btw hahaha
    None of us are as cruel as All of us. - Anonymous
    Mar 2009
    Cairns White Rock
    Kieran, you can only connect a second sub to your amp if it is stable at lower than 4 ohms. One sub on it's own will produce a 4ohm load to your amp,(unless your allready taking into account the voice coil configuration that gave you 4ohm)
    A second sub will bring the load down to 2 ohm. Most mono block amps though should at least be stable at 2 ohm, what amp do you have?
    Otherwise so long as the amp is presented a suitable load, the power will be divided equally between the subs.
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    Thanks guys.
    So, don't go for the peak rating. At my car audio shop they only talk peak wattage, thought i would ask people who aren't after my money.
    My understanding of peak value is that it is estimated by the manufacturer.
    So you just need to cover the rms rating of the sub.
    Ryda are selling these subs at the moment for $148 each
    JBL GT515 15" Car Subwoofer - RYDA Car Audio($148.85)
    Mar 2009
    Cairns White Rock
    Power isn't always relevant as music is dynamic, the subs will run with 5 watts, they will also run with 5000 watts, it's entirely up to you and the application.
    VX Exec M5
    Apr 2010
    Melbourne, Bundoora
    Thanks HCVP. It was more of a, "for later on down the road" type question.
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by Kieran263 View Post
    Well it would still help to know the model number of the amplifier, because like i said most, if not all, mono block amps will run at 2 ohm. There's not many applications where they are set up to run at 4ohm.
    VX Exec M5
    Apr 2010
    Melbourne, Bundoora
    It's an MB quart Onyx 1000D mono, rated at 475wrms @4ohm, 750wrms @2ohm and 1000wrms @1ohm.
    It will be amping 2 JBL GTO1214 single voice coil subs, they're 350wrms @4ohm.
    So this means the subs would be getting 375wrms @2ohm each?
    VY S/II S Pack
    Apr 2011
    VX Exec M5
    Apr 2010
    Melbourne, Bundoora
    Hooray, thanks guys, kinda hijacked the thread a bit hahahaha
  1. 15's for 17's
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2008, 09:01 PM
  2. Pick Some 15's For Me !
    By VT Berlina 07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2007, 08:27 PM
  3. VN-VP can't do 15's in V6 Auto's Stock. Ever
    By Full Spectrum in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2006, 01:26 AM
  4. 2 15's
    By Stretchomatic in forum Car Audio
    Last Post: 30-09-2005, 02:24 AM
