Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By StoneX
Thread: Risking 1ohm on a 2ohm stable Pioneer amp
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    Default Risking 1ohm on a 2ohm stable Pioneer amp
    Hi,
    I want to hook up 4 x kicker comps 4ohm svc and wire them to 1ohm parallel back to the amp.
    My amp is only rated for 600rms at 2ohms (Pioneer GM-D8500M).
    Will the amp function properly with 600rms at 1ohm?
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Wouldn't recommend it...
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    VY Berlina V6 / R31 Skyline
    Dec 2008
    4 single 4ohm subs wired parallel does not equal 1 ohm, it will be less than 1ohm. Your amp will go into protect and not function, or it will overheat and blow up, or just blow up.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Four 4 ohm subs in parallel is 1 ohm (nominal). I would not risk your amp at 1 ohm, it will blow eventually.
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Might be fun for a few second tone burst though
    Ronald Reagan (1986)
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Quote Originally Posted by sweefu View Post
    Yes it does. Have a look through your high school physics text books..
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by davey g-force View Post
    That's on paper, you have impedance curve, dips ect, it will drop to below 1 ohm, which is when the problems will happen.
    VY SS
    May 2011
    Auckland
    Is the amp a mono or 2 channel?
    You could wire it to 4 ohm or 2, 2 ohm loads
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It's a mono amp that does 600Wrms at 2 ohm or 300Wrms at 4 ohm. He can't get 4 ohm with four 4 ohm subs unless he wires in series which should not be done.
    VL Wagon
    Aug 2010
    Adelaide, Australia
    Quote Originally Posted by HCVP View Post
    it won't drop below the dc resistance, chances are it won't even get that low.
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by AmmoJammo View Post
    Isn't dc resistance measured at rest and then rounded up by manafactuers to give the nominal impedance value ? That's always been my understanding, but i don't know much more than that about it. I've seen a few impedance vs fq graphs though where the impedance level has still dropped before rising again. I wouldn't do it personally, not on his amp anyway.
    Sep 2005
    I think it's pretty clear that he shouldn't do it - nobody's arguing that.
    What we're saying is that if you wire up four x 4 ohm speakers in parallel, you'll get a 1 ohm load - not lower.
    VY SS
    Jun 2006
    Albany
  15. #15
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by axemurderer101 View Post
    But again that would involve wiring them in series we (most people) don't do that.
  16. #16
    VY SS
    Jun 2006
    Albany
    why cant you wire them in series?? as others have said wiring it to 1ohm will most likely do damage so wiring it to 4ohm is the only way you will get it to work. otherwise buy an amp that is stable at 1ohm
  17. #17
    VL Wagon
    Aug 2010
    Adelaide, Australia
    just wire it at 1ohm.
    if the amp dies, good, then you can buy something more suitable
  18. #18
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    Rofl. Thank you all for replying.
    I just went with 2 x 300rms DVC Soundstream SST - 12/2 and the old kickers are siting in the garage now.
    I Highly recommend these soundstream subs. When I pump it you can feel the bass in your chest and body, every hair you exposed have tingles. The sunglasses opens by itself near full volume . They pump about 1.75 times more then the kickers.
    Subs only cost me $100 each. The owner told me he bought 50 of them for a good price, otherwise normally he would pay $100 each for them
  19. #19
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Back-EMF
    Quote Originally Posted by http://www.jlaudio.com/header/Support/Tutorials/FAQ%3A+Dual+Voice+Coils+%28DVC%29/FAQ%3A+Dual+Voice+Coils+%28DVC%29+/656154
    It is far less desirable to make subwoofer to subwoofer connections in series. Due to slight and unavoidable differences between speakers and the high likelihood of uneven loading between different speakers in a car, there will be slight differences in the mechanical behavior of the two speakers in series. These differences in movement result in the creation of induced voltage (called back EMF) by the speakers across the series connection. This effect causes a problem when two speakers that behave differently are connected in series because the speakers can modulate each other (cause each other to move), resulting in distortion. The problem becomes more serious as more speakers are connected in series.
  1. [VIC] Digital Designs M3 Amp 2600rms @1ohm!!!
    By Gunns VC in forum Parts And Other Items For Sale
    Last Post: 23-08-2010, 01:38 PM
  2. Pioneer Amp + 2ohm or 4ohm Sub?
    By RachRocks in forum Car Audio
    Last Post: 22-06-2010, 01:35 AM
  3. Jaycar AA0424 stable at 2ohm?
    By levymetal in forum Car Audio
    Last Post: 02-10-2009, 11:26 PM
  4. Wiring Kicker CVR DVC 2ohm at 2ohm load?
    By ruso in forum Car Audio
    Last Post: 26-07-2008, 04:20 PM
  5. NORTI's Stable..... VK Calais VN 'S'
    By NORTI in forum VB - VC - VH - VK
    Last Post: 14-06-2008, 07:47 PM
