Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By StoneX
Thread: Opinions on Amps..
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    Default Opinions on Amps..
    Ok so I am looking at installing my 12" Pioneer Sub into my VZ SV6. But I need a new amp. Im relatively a noob when it comes to audio stuff, I mostly keep my head under the bonnet rather then this stuff so just looking for some advice. My budget is minimal, looking at amp's around the $200 mark, so I know Im not going to have anything outrageously awesome. Am looking at either Option 1: 4 channel amp to run the sub, and also the 6x9's in the rear parcel shelf, or Option 2: just a 2ch or mono amp to run just the sub and leave the speakers standard install for now.
    Would this Fusion Amp be enough to run Option 1?
    1800 Watt 4 Channel Amplifier (CA-AM40700) | FUSION Electronics
    Or this Pioneer? (Can get it on ebay for $200 & free postage)
    GM-6500F 4 Channel Bridgeable Amplifier (760W) - Pioneer Amplifier
    Or if I was to go Option 2, would this mono amp be suitable enough?
    Digital Mono DRVN Amplifier | Amplifiers | JVC Australia
    Or would a 2ch bridged be better?
    GM-5500T 2 Channel Bridgeable Amplifier (820W) - Pioneer Amplifier
    And for reference, this is my sub
    TS-W306DVC (Archived) - Pioneer Europe
    Quote Originally Posted by old mate View Post
    gas is for bbq's.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    Specifications of sub as per link at bottom:
    Key features Pioneer TS-W306DVC
    Composite IMPP cone using interlaced Aramid fibre with reinforcement arcs
    Wide-roll, 3-layer fibre woven radial surround
    Dual mass high power magnet
    Extended and vented pole yoke
    Enclosure use
    Optional accessories:
    - UD-G306 spoke grille
    - UD-W301S custom enclosure box
    Ohm Rating: 2 or 8Ω
    Dual voice coil subwoofer
    Features TS-W306DVC
    Frequency response 18 - 500 Hz
    Sensitivity (1W/1m) 89 dB
    Recommended sealed enclosure (Litres) 24 - 49.6
    Lowest resonance frequency (FS) 32.9
    Maximum Power 1.000 W
    Nominal input power 400 W
    Woofer size (cm) 30 cm
    gas is for bbq's.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You sure it's a TS-W306DVC? I'm pretty sure only the TS-W306C were sold in Australia. Did you import it?
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    I like to stick with D Class amps for powering subs so that JVC amp running at 2 ohms would be a good match. Just make sure you run some extra RCA's to the boot incase you decide to get a 2 or 4 channel amp later for the 6x9's. If you really want decent sound piss the 6x9's off and get some decent splits for the front.
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    Whoops. I stand corrected. Thats what I get for rushing through a google search and pasting links without double checking. I believe it is the TS-W306C then.
    Specs.
    Watts MAX. Music Power 1000 Watts
    Watts Nominal Power Handling 400 Watts
    Frequency Response 18 ~ 500Hz
    Sensitivity 89dB
    Ohm Rating SVC:4, DVC: 2 or 8
    Recommended Enclosure 0.85 ~ 1.75 Cubic Fe
    gas is for bbq's.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Since that sub likes some decent power (300Wrms+), you're better off going with option 2 as there is very few 4 channels that will make 300Wrms+ when bridged.
    That sub is 4 ohm single voice coil so you can get a mono amp and run it at 4 ohm, which is kind of a waste because they're made to run at 2 ohm OR you can get a big 2 channel amp and bridge it to make 300-400Wrms at 4 ohm. That Pioneer 2 channel seems like a good match.
    Monaro CV8R, Landcruiser 100 Series 4.7L
    Jun 2011
    Quote Originally Posted by torana355 View Post
    I bought a JL 5 channel d class and it does everything. They are small and efficient and still deliver the goods. The system comprises Alpine splits in the front (not sure the spec, they were in there when I bought the car), Alpine R coaxs in the rear panels and two JL 6.5 6W3v3 subs in the rear shelf factory position. It’s not a “doof” wagon but it plays music very well. This is my first foray into D class amps but I am sold. Only problem is I wanted to make a bit of a display in the boot with the amp mounted but it is actually so physically small it looks lame! LOL.
    I bought the amp and rear Alpines off Amazon. Quite a bit cheaper than locally.
    Amp
    XD - JL Audio »
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Macca... Torana and Crisis's info is not suitable for you as the amps they're referring to should be used on a 2 ohm sub, they won't give your 4 ohm sub enough power.
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    Thanks StoneX. Much appreciated. I think I'll go with the Pioneer GM-5500T 2 channel amp I posted the link to above that you said should be a good match. I can get a good deal on one atm so might get it while the gettings good.
    Cheers everyone
    gas is for bbq's.
    Jun 2011
    Quote Originally Posted by StoneX View Post
    As I said it is not a doof mobile but my point was more about a recommendation of D class amps for full range work, not recommending he buy the one I did.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by Crisis63 View Post
    Yeah, I understand. I wasn't personally attacking you, just wanted to make sure the OP bought the correct product to match his subwoofer
  1. which amps ?
    By HKTKWG in forum Car Audio
    Last Post: 08-09-2009, 10:35 PM
  2. How do i run 2 amps?
    By MG's VH Wag in forum Car Audio
    Last Post: 05-03-2009, 11:36 AM
  3. how do i run two amps?
    By Haydz in forum Car Audio
    Last Post: 04-01-2008, 01:12 PM
  4. 2 Amps.. How?
    By tr3nt in forum Car Audio
    Last Post: 16-06-2006, 10:29 AM
  5. Amps
    By ducatis in forum Car Audio
    Last Post: 27-07-2005, 03:15 PM
