Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree1Likes
Thread: Running Type R splits off headunit? stupid??
    VX Berlina II
    Sep 2011
    Default Running Type R splits off headunit? stupid??
    hey today i bought some 6.5" Alpine type r splits for my front doors although i dont think ill be worrying about an amp or atleast not anytime soon, am i stupid running 110w RMS speakers off the headunit? will this cause any damage or does it just mean im not getting everything i could be out of my speakers, not being on an amp will they still sound better then other speakers like type S or will they be the same unless i amp them? also putting these speakers in the front doors should i disable the rear door Stock speakers or will it sound ok mixing them?
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    its pointless buying good speakers without amping them IMO... you can pick up a decent 4ch amp fairly cheap that way they will sound better and you can also upgrade the rear speakers off the same amp... its not hard to install an amp even if you want to keep the stock head unit you'll just need a line level convertor.
    If in doubt......FLOOR IT!!!
    VX Berlina II
    Sep 2011
    Quote Originally Posted by juiceie vh sle View Post
    what kind of amp would i need to handle the 110 rms? can you suggest any from the jb site as they have 30% off all car audio for boxing day i could just put one on lay by if they let u do that on boxing day sales? and do i get a 4 channel or mono amp? i do not know the difference and what each type is for, thanks
    Mar 2011
    roxby downs
    not to sure how much you want to spend but i would go with this
    alpine 4ch amp - if you want to upgrade the rear speakers aswell
    sony 4ch amp - this will do if your on a cheaper budget
    kicker 2ch amp
    - use this if you only want to amp the front speakers
    MONO amps are only for subwoofers.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Quote Originally Posted by daNc View Post
    Something like the Jaycar 4X100wrms will be better than anything JB will try and sell you for the same price range.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Jaycar amps are pretty decent. Type R's aren't that dependent on amps.
    VX Berlina II
    Sep 2011
    kicker 2ch amp
    i could afford that alpine one although it says 75w (RMS) X 4 does this mean i would still not get everything out of my speakers since they are 110 RMS not 75? cheers
    VX Berlina II
    Sep 2011
    in the future i will get some 6x9 splits for the rear shelf so i will need a 4 channel amp right and with good speakers in the rear shelf i can just disable the rear door speakers then? that would be my best option?
    Mar 2011
    roxby downs
    as i take it your not building a compatition system it isnt neccessary to run everything at its peak wattage
    75w rms will sound a million times better then the factory wattage
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    The Jaycar are more than capable of running the type R's efficiently. They're rated at 100wrms but they actually produce around 120wrms.
    VX Berlina II
    Sep 2011
    Quote Originally Posted by showbags View Post
    would of thought a well known brand like alpine would beat jaycar?
    Mar 2011
    roxby downs
    if ya can get this at a decent price i would go for this option
    VX Berlina II
    Sep 2011
    there is this jaycar one for $230 dont know how it compares to the alpine one whats worth about $350 when not on sale
    http://www.jaycar.com.au/productView...UBCATID=1028#4
    Mar 2011
    roxby downs
    i havent had anythig to do with jaycar amps in the past so i wouldnt know if there any good or not.... but i've always found that its easier and safer to stick with the well known brands
  15. #15
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Alpine is one of those companies where they think they can charge more because of the brand.
  16. #16
    VX Berlina II
    Sep 2011
    ok thanks, will i damage anything if i run the powerful speakers off the head unit which is 15-18 rms or w/e? dont know the difference in sound im going to get going from stock to the type r's if they are only running off the head unit lol
  17. #17
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    The sound will still be better going from horrible standard speakers to splits either way but an amp will sound better again.
  18. #18
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    I think your in Geelong aren't you daNc? I've got amped type x & type R's in my VT Calais. PM me if you want to listen to what they're like incar.
  19. #19
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
  20. #20
    VT SII 5.7 LS1
    Jan 2008
    Albany, WA
    Quote Originally Posted by wraith View Post
    Very true.
    +1 on the jaycar amps. I have two and have never looked back.
  21. #21
    VX Berlina II
    Sep 2011
    Ok thanks i will get a jaycar response amp they have a 4x100rms AB Amp and a 4x100rms Digitial amp, what is the difference between the analog and digital and whats going to be better, im only going to have 4 speakers running off it, the digital is $70 more thanks, also where is the best place to get it mounted? under the passenger seat or in the boot? or somewhere else? thanks
  22. #22
    VX Berlina II
    Sep 2011
  23. #23
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
  24. #24
    VX Berlina II
    Sep 2011
    Go the digital one. It's more efficient and doesn't draw as much power.
    any difference in sound at all? the guy in the shop said the AB one had a little more power but im not sure if he knew what he was talking about or not
  25. #25
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    If your talking about Jaycar in Geelong, thouse clowns have got no idea. Go the digital, it's a much better amp than the AB. Theyre just trying to get rid of old stock.
  1. Replies: 1
    Last Post: 15-12-2010, 09:45 PM
  2. Replies: 18
    Last Post: 11-12-2010, 12:19 PM
  3. Replies: 9
    Last Post: 26-02-2010, 04:55 PM
  4. setting up splits (jvc headunit)
    By VNexecutive in forum Car Audio
    Last Post: 30-09-2008, 07:18 AM
  5. 6" Splits Alpne Type R??
    By colk in forum Car Audio
    Last Post: 03-09-2007, 09:12 PM
