Results 1 to 6 of 6
Thread: Jaycar amp: Class AB or Digital?
    VX Berlina II
    Sep 2011
    Default Jaycar amp: Class AB or Digital?
    hey, im looking at getting a jaycar amp soon (links below) they will be for powering 6.5" Alpine Type R splits which are 110 rms, in the future ill also get some rear shelf speakers to hook up to the amp, so anyone which is going to be better to run these speakers off Digital or Class AB? they are both 4x100 RMS, the digital is $70 more, also where will the best place be to mount these amps? are they best under a seat or mounted in the boot? i wont be doing the install myself. Cheers
    Class AB - Response Precision 4 x 100WRMS Class AB Amplifier - Jaycar Electronics
    Full Range Digital - Response Precision 4 x 100WRMS Full Range Digital Amplifier - Jaycar Electronics
    VY S/II S Pack
    Apr 2011
    You were given an answer in the other thread...
    Quote Originally Posted by AmmoJammo View Post
    I wouldn't get the digital for full range speakers. In the past, I've found them to have noise because its a class D amp.
    If you're limited in space, and want the most power from a smaller amp, then yes, get digital.
    If you've got room for a larger class AB amp, then go for that!
    VX Berlina II
    Sep 2011
    Quote Originally Posted by MAG00 View Post
    i got two different answers so i thought i would open it up and see what other thought as well
    VL Wagon
    Aug 2010
    Adelaide, Australia
    the digital amp will draw less power to give the same power output, advantage? well, I guess if you have a small alternator or battery, then maybe?
    other wise, there's not much point.
    if it was the same price, then yeah, maybe get the digital amp.
    VX Berlina II
    Sep 2011
    Ok thanks, can you fit the larger AB one under a seat or are they best kept somewhere else? i have no idea with installs lol
    VL Wagon
    Aug 2010
    Adelaide, Australia
    I have the old silver 4x100watt ReSponse amp "under" the seat of my ford laser, you should be able to fit one in a commodore, but I don't have a commodore, and don't know how the dimensions of the new/old amps compare.
  1. Bit more class for the VY
    By Sebastien in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-03-2009, 07:45 AM
  2. class d digital amp
    By Torquative in forum Car Audio
    Last Post: 01-10-2008, 09:27 PM
  3. new jaycar digital amp
    By garfa in forum Car Audio
    Last Post: 08-05-2006, 07:20 PM
  4. Class AB or Class D??
    By Cameron in forum Car Audio
    Last Post: 25-10-2005, 04:21 PM
  5. jaycar class d amp.
    Last Post: 14-10-2005, 07:51 PM
