Hey guys, ok so my headunit has been working fine for the past 6+ months but the other day it just decided to not work at all.. I've checked all fuses, checked wiring, made sure i had a constant 12v and changed the headunit but nothing worked or showed problems. It won't go on at all.. Tried pressing all buttons and using the remote for both, Any ideas what the problem could be? cheers.
could be faulty, what head unit is it?
Would need to be a clairvoyant to help with that much info.
HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
What other info do you want then? it's a pioneer deh-1250mpg and the headunit i switched it with is a pioneer deh-1350mpg
so whats the issue? you said you changed the headunit? did the replacement work or not?
Maybe i worded it wrong but yes as isaid in the OP i chaged the headunit but the problem was still there, all good now though did some more troubleshooting and it's now fixxed.
