Hey Guys can someone tell me how hard it is and whats the easiest way to run new speaker wire from the front doors into the Cabin area to run to my X Overs please..
Would appreciate it., I've looked and not confident with moving too much around at the moment, without some direction
Brendon
Remove the kick panels, find where the loom meets to the door, pull the rubber loom hose thingo from in between the door and the cabin, feed wires through from cabin, into the loom rubber hose thingo, then into the door. Re attach the rubber loom thingo to the door and the cabin.
Thanks Sweefu... I appreciate that Mate, It's been a little challenging so far with some spots ive had to get to..lol
The last time i've done an install was my VH Commodore..lol
No worries mate, that method should be pretty straight forward and easy.
I found that the "rubber loom hose thingo" was already quite full with wiring, to solve this issue I taped the wiring to a large flat head screw driver, lubed the bitch up with some white grease and pushed it through with ease. Then of course remove the tape, get a good grip on the wire and pull the screw driver back out.
So some Vaseline do the Trick? LOL!!!!!!
Mate, your choice of lubricant is up to you ahaha![]()
Hey Baby oil did the trick, I got 12Gauge speaker wire through the door looms no probs at all!! Good Quality Stuff right there!!!))
Good on you mate, bonus ess ques for you.
Hey Sweefu, What sort of LED's could I put in my Sub Box...? I was thinking some Pc Led's and just cut the Molex plug off and Wire to + and - Power source in the car...?
I've used these throughout my car
Cheap and you can make them the length you like, very compact. All you need to do is cut/solder the ends as you need.
