Results 1 to 18 of 18
Thread: Crossover question
    Wk Statesman
    Aug 2010
    Default Crossover question
    I am in the process of replacing my front speakers of my WK Stato, and just want to ask do I need to run the crossovers that came with my speakers (Morel Maximo 6) or will the standard setup in place be sufficient.
    Cheers Miki
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    VY Berlina V6 / R31 Skyline
    Dec 2008
    You must run the cross over provided in the speaker set, cross overs are not universal and the stock holden setup has no external cross over, rather a resistor on the tweeter.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VL Wagon
    Aug 2010
    Adelaide, Australia
    Quote Originally Posted by sweefu View Post
    capacitor
    Wk Statesman
    Aug 2010
    Cheers guys, had a feeling I needed to. Next question. which wire would I run to the crossovers, the ones from the speakers or the tweeters? Ordinarily I would split the speakers, but I have never replace a stock tweeter before.
    Dec 2008
    Quote Originally Posted by AmmoJammo View Post
    capacitor
    Damn it!! Too late :P
    Quote Originally Posted by silv View Post
    Run the tweeter into tweeter, woofer into woofer and headunit / amplifier into amplifier.
    Wk Statesman
    Aug 2010
    Maybe I should reword it. Currently there are two separate lines. One line goes to the tweeters and the other goes to the woofers. My crossovers have one input, so I was trying to ask which one do I use for the input.
    VY S/II S Pack
    Apr 2011
    Okay, let's go back to the beginning here. This separate wiring you are referring to, is it wiring you have laid or is it stock wiring?
    It sounds to me you have wired it up so you can go active (without a crossover), which for a novice user is just silly as you can damage the speaker set.
    What you want is this:
    A pair of left and right +/- wires from your headunit or amplifier to the AMP +/- on your left and right crossovers.
    You need +/- wires from the TWEETER output on the crossovers to the +/- terminals/wires on your tweeters.
    And finally you need +/- wires from the WOOFER output on the crossovers to the +/- terminals/wires on your woofers.
    Wk Statesman
    Aug 2010
    It is all stock wiring. It has one set for the woofers and another to the tweeters. I haven't pulled the dash out and I am assuming that they are separate lines from the head unit.
    If it were a standard setup i.e fresh setup for the tweeters, I would be fine but I haven't changed out a stock setup like this before. The wiring from the crossovers I understand (straight forward) it is just the input I am having trouble with.
    Should I wire both the current woofer and tweeter wire to the crossover input then just split them as normal? Just not sure what the go for it is.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Wk Statesman
    Aug 2010
    VY S/II S Pack
    Apr 2011
    I believe they are the same wire, just split to the tweeters. So yes, just leave tweeter wire hanging.
    VY SS
    May 2011
    Auckland
    So just leave the standard tweeter wiring hanging?
    Yes. Factory setups don't usually have a low pass on the woofer. Just allow the woofer to play up to its mechanical limits. Insulate the tweet wires do they don't touch each other or metal .
    For your reference a capacitor in series and parallel with resistor form a first order high pass and low pass filters.
    Are you running your splits straight off the headdeck?
    Wk Statesman
    Aug 2010
    Yeah straight off the headunit, that is until I put the crossovers in. Now I know my plan of attack, cheers guys, much appreciated.
  15. #15
    VL Wagon
    Aug 2010
    Adelaide, Australia
    I'm a bit confused? running off the headunit or not, you still need the crossovers...
  16. #16
    VT S2 - SS intirior - Ls1 Project!
    May 2011
    Sunny coast
    cut the plug off the door wire, theres your inputs.. all you need.. tape up separatly the tweeter wires or heatshrink etc..
    simple question and i think all the over the top post's have just made it confusing?
  17. #17
    Wk Statesman
    Aug 2010
    Just to clarify.
    I am going to use the wires that currently come off the headunit to the stock speakers as the input to my crossovers, and then do a woofer/tweeter setup from there.
  18. #18
    Dec 2008
    Yep, that will be fine.
  1. VZ Crossover 6 bumper
    By cwmorgan101 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-05-2010, 10:31 AM
  2. where to put the crossover?
    By ephect in forum Car Audio
    Last Post: 26-09-2009, 11:41 PM
  3. Crossover Question
    By Crossy_014 in forum Car Audio
    Last Post: 22-06-2009, 10:19 PM
  4. Crossover question?? + Sub Q
    By MikeVXSS in forum Car Audio
    Last Post: 19-03-2007, 10:27 PM
  5. Crossover Problem
    By vtwgn in forum Car Audio
    Last Post: 19-03-2007, 01:20 PM
