Results 1 to 7 of 7
Thread: Advice needed about building a sub box!
    VY Berlina
    Jan 2012
    Nunawading
    Default Advice needed about building a sub box!
    I am planning to build a sub box for my Alpine SWS-3049. The specifications sheet recommends the sub in a sealed box of 123 litres (yes, I know this is quite large).
    To my calculations (and to fit in my boot), the following dimensions work out at 123 litres:
    Height = 32cm
    Width = 90cm
    Depth1 (top) = 36.708cm
    Depth2 (bottom) = 42.708cm
    Note that this is a rectangular box with a slanted front.
    I want to place the sub in the centre on the angled front, but this leaves a lot of empty space either side of it. To clarify, the box is a lot wider than it is deep.
    Will this effect the sound quality, or will it be okay? Or would it be better to build a box of more square-like dimensions?
    EVIL304
    Oct 2011
    Quote Originally Posted by AdamJaffrey View Post
    Height = 32cm
    Width = 90cm
    Hi hows it going i think the key word here is (recommends)
    VY Berlina
    Jan 2012
    Nunawading
    So do you think that size box is too big?
    The question still remains, does it matter where on the box that the sub is mounted? I'd still like to have it 90cm wide because it will fit nicely in my boot at that size. Can I put the sub in the middle of the long side and still get good sound quality?
    troykinsvt's Avatar
    troykinsvt is offline yes i like fibreglassing
    VT
    Oct 2011
    helensvale
    i think it depends on how many watts the sub is i have two 12" 800w subs in an 80cm long by 40 wide at the base 30 wide at the top built myself and i have a port hole sounds pretty decent , i mean ive heard better but ive got no complaints
    stroking is fine but id rather be blown
    EVIL304
    Oct 2011
    If it was me i would be building a box that best suits and fits in my boot. As far as mounting the sub its self i would have it in the centre of the front side of the box. I dont think its really going to matter i had a car once with the sub just mounted on a sheet of MDF and fixed to the back seat and no box surrounding it at all and i must say it was pretty good.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    ...Will this effect the sound quality, or will it be okay? Or would it be better to build a box of more square-like dimensions?
    No, it won't effect the sound quality., it will be fine. The box is mainly there to provide air suspension for the speaker when the cone moves so the shape does not matter. Some people say having a cube box is bad due to reflected sound waves in the box but I can't see how that would effect the sound waves outside the box. Anyway, it's not relevant to your box anyway.
    I'd look up that sub on other forums and see if people recommend a smaller enclosure though. That volume is usually what 'free-air' subs require.
    VY Berlina
    Jan 2012
    Nunawading
    Quote Originally Posted by StoneX View Post
    Awesome advice, thanks for the help!
    Yep, I'll take a look around and see what others say since 123 litres is a very large box.
  1. Building new PC advice
    By HamaTime™ in forum The LAN Lounge
    Last Post: 01-12-2010, 11:43 AM
  2. Advice on building some SPL sub boxes
    By acarmody in forum Car Audio
    Last Post: 13-09-2010, 07:30 AM
  3. Just need a little advice on sub box building.
    By ethann in forum Car Audio
    Last Post: 14-07-2010, 10:18 PM
  4. building a new pc and need advice
    By Jezza in forum The LAN Lounge
    Last Post: 03-07-2010, 04:12 PM
  5. Replies: 28
    Last Post: 28-07-2008, 08:12 PM
Tags for this Thread
