Results 1 to 11 of 11
Thread: installing a single din.Where Is The Handbrake wire?
    Granny Spec Vs Factory 5 Speed
    Jan 2012
    Tasmania
    Exclamation installing a single din.Where Is The Handbrake wire?
    Im installing a single din and really dont have a clue where the hand brake wire is that i connect the safety wire to? or or there a way i can bypass it? i know its illegal but it would be handy to have on long drives, can anyone help a noob out please
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    VY SS
    May 2011
    Auckland
    You connect it to the switch on the handbrake.
    Is it a tv screen or does it just lock you out of features? If its a tv I'd connect it to the handbrake and just have a hidden bypass switch. That way if you get pulled over its legal.
    Jan 2012
    Tasmania
    Its a clarion vrx485vd, and it doesnt work if you just ground it, alot of people say use a switch but where do you put the swich?
    VY SS
    May 2011
    Auckland
    If grounding it doesnt work then it must need 12v at it. Please confirm this in the manual first though.
    Using a 2 way switch you connect the handbrake wire (from heady) to centre. Then connect wire from the handbrake to one side. And either ground or 12v to the other side. This way by flicking the switch the heady thinks the handbrake is on.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by m1lky View Post
    No, head units are getting smarter. It's not just a simple ground or 12v trigger anymore, Clarions need the handbrake wire to change state before it will acknowledge the handbrake wire.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by StoneX View Post
    This is when we start using relays
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    VY SS
    May 2011
    Auckland
    Useless safety features. You could fake that with a switch pretty easy. Tell it that it's gone from open circuit to ground.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Yeah, you need to flick a switch, no more hard wiring to ground with certain brands anymore.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    clarions just need to be hard wired to a ground with a switch inline . Flick the switch on then flick it off and back on and it should work. Thats how I wired my clarion dvd screen/head unit up
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    US spec Pioneer units need a relay fitted now for same reason , the sneaky pricks !
    Aus models straight to ground.
    Right click save as . .
  1. VU radio wiring and handbrake wire ?
    By Ptb in forum Electrical Wiring / Questions
    Last Post: 27-11-2011, 10:08 AM
  2. single black wire to trimatic
    By ari666 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-10-2009, 03:49 PM
  3. Installing Alloy Auto Shifter & Handbrake Cover
    By flc in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2009, 08:47 AM
  4. 1 wire or 2 wire O2 Sensor
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2009, 10:05 PM
  5. Handbrake Wire
    By ducatis in forum Car Audio
    Last Post: 16-11-2006, 12:51 PM
