Results 1 to 6 of 6
Thread: How to disable auto CD check at startup
    VY 5.7
    Dec 2011
    Jubail
    Default How to disable auto CD check at startup
    A couple of days I was messing around with audio controls and I pressed "load", after that the player is checking for CDs constantly at every startup which is very annoying.
    I have trying turning the system off and then on, but no use.
    Any help please.
    Thanks
    VZ Berlina
    Oct 2009
    Melbourne, VIC
    Hey there!
    What is the make and model of your head unit? Someone might be able to help you more specifically if they have the same or similar model.
    However, if you just want to clear out all the settings you can just disconnect your battery, this will wipe any saved settings (incl. saved stations etc) in the H/U.
    Cheers.
    My VZ Berlina : The Audio
    DIY Enthusiast
    IT Professional - If you need honest advice about computers/tech, shoot me a PM
    VY S/II S Pack
    Apr 2011
    I believe he is referring to the stock headunit. Mine always did it from memory, I don't think you can bypass it.
    VY 5.7
    Dec 2011
    Jubail
    @Zend3r, Its the stock one, I haven't upgraded it yet,
    @MAG00, Well, that's the problem. It didn't do it until i messed around with the CD controls
    VY S/II S Pack
    Apr 2011
    VY 5.7
    Dec 2011
    Jubail
    ... I don't think that much options are remaining
  1. Can you disable startup chime?
    By Thumpin in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-06-2011, 05:49 PM
  2. memcal for s2 vs auto disable security function
    By jayrad in forum Electrical Wiring / Questions
    Last Post: 08-01-2011, 07:59 PM
  3. Auto Lights Default on startup?
    By ascottaudio in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-04-2009, 12:50 AM
  4. how do i disable the auto boot light on a VR wagon?
    By littvrwagon in forum Electrical Wiring / Questions
    Last Post: 03-03-2008, 08:20 PM
  5. VR V6 Auto Fluid Check?
    By Driver 111 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2005, 05:32 PM
