Results 1 to 25 of 25
Thread: factory Tweeters?
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    Default factory Tweeters?
    i have been doing some research on installing splits and i read that there are factory tweeters in the vy, i seriously did not know this, would anyone be kind enough to tell me where they are?
    thanks
    Nic
    VY Calais
    Jun 2010
    Sydney, NSW
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    VY S/II S Pack
    Apr 2011
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by MAG00 View Post
    That's it. Requires the removal of around 6 pieces of trim to get to.
    ohh ok, is it easy?
    VY S/II S Pack
    Apr 2011
    Very easy, just screws here and there. The hardest part is trying to not break the clips.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    MAG00, would you be kind enough to tell me which panels i need to take off to access the tweeters, i am going to atemp it 2morro
    plawx?
    thanks bud
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Haven't you had tweeters running at all?
    Open either front door, look at the panel just below the tweeter grill and you'll see the demister grill that goes into the door, in there is a screw pull that out and pull off that panel. then you'll see another screw under the tweeter grill pull that sucker out and then you'll have to pull on the actuall demister panel under the front windscreen.
    It has like 3 clips that will release.
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by kcpwns View Post
    nup, i have had the same 4 coaxials in there ever since the first install (couple years ago)
    i havnt really felt a need for components untill now
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Read my edit^
    My Ride
    VY S/II S Pack
    Apr 2011
    Left side: Glove box, side of dash air vent with and the top piece of plastic underneath the windshield.
    Right side: Fuse area cover, side of dash air vent and the top piece of plastic underneath the windshield.
    The side air vents have 3 screws each from memory, two on the front (would be covered by glove box and fuse panel) and one inside the vent.
    The top pieces of plastic underneath the windshield are bitches to get out, easiest way would probably be to unscrew the end (which would normally be covered by the side of dash air vent) and gently pry from the middle with a small flathead screwdriver. The clips are solid, you'll need a fair bit of effort to get those pieces out.
    Part 4 of this guide covers it: Full stereo install guide, VZ SV6
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    now i got some crossover questions :P
    where is a good place to put them? i was thinking on the peice of wood i have behind the back seats next to the amps if it fits,
    and there are no screw holes for them and i was thinking of using sikaflex and leave the plastic that is stuck on the bottom (packageing) and stick it to that so if i ever remove them for what ever reason the sikaflex wont get stuck to the crossover??
    any suggestions ?
    VY S/II S Pack
    Apr 2011
    Up to you, if you don't plan on ever going active then it's just easier to have them where you save as much cable as possible. I used to have mine stuck to the door with double sided tape. Best place for them to minimize the cabling used is in the door or in the kick panels. Another option is adhesive velcro strips. As far as I know sikaflex is pretty robust, I would just settle for double sided tape or adhesive velcro strips.
  15. #15
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    the velcro strips i have melts in the heat, screwed me around with the dash mat
    and the double sided tape i have is crap (thin & also melts)
    i think mum got the velcro from K-Mart and teh double sided tape from Woolworths..
    if there on the door, wouldnt the wires be showing and that
  16. #16
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I've put them in the sides of the dash... Behind and below that side air vent panel. Saves running two sets of wires the length of the car for both sides.
  17. #17
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  18. #18
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Quote Originally Posted by Nic92 View Post
    Use the 3M brand Velcro strips. The glue on them doesn't melt in the heat.
  19. #19
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by showbags View Post
    but where do you get them from ?
  20. #20
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  21. #21
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by StoneX View Post
    Hardware store.
    Bunnings? i can go there in the morning then get started on the doors/dash
  22. #22
    VY S/II S Pack
    Apr 2011
    Underneath the trim of course..
  23. #23
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    ohh hehe, i have seen them on doors and look ugly. il have a think about it tomorro
  24. #24
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Sorry, my reply was delayed and was actually replying to you asking where to get good double sided tape.
    I assume Bunnings would have some as they have everything else.
  25. #25
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    umm na all good, im going to try the stuff i have already or il just go out and get some. (if i can find it)
  1. tweeters
    By rage_against in forum Car Audio
    Last Post: 13-11-2011, 11:16 PM
  2. How to connect Vt acclaim Factory Steering wheel buttons to FACTORY STERO
    By logan79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2010, 01:57 PM
  3. Too many tweeters?
    By Crossy_014 in forum Car Audio
    Last Post: 24-06-2009, 08:14 AM
  4. vt tweeters
    By SthEastCustoms in forum Car Audio
    Last Post: 11-03-2008, 06:38 AM
  5. tweeters
    By StatOmaN in forum Car Audio
    Last Post: 22-09-2005, 01:39 PM
