Hey
my subs were just workin perfetly and next minute they just cut out i spouse it either a blown fuse in the amp? or what not. i havent check it yet but i suppose it is?
any idea other then that?
lol.......
if its not a blown fuse check the wires are all in snug... a common problem is that your earth may have come loose from wherever you grounded it.. dont forget to check the main fuse that runs to your battery
What does your boot smell like? lol
Whats your setup, professional install and how long have you had it for?
My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
simple check for the subs,get a AA battery and 2 wires, put the wires on the + and - on the sub or box terminal and put the other ends of the wires onto same polarity on the the battery briefly. Sub cone should move outward,meaning voice coil is not blown.
