Hey,
Does anyone know if the INPUT to the OEM sub amp in a VE is low or high level? No guessing, please. I need to know for sure as I have an aftermarket amp that will turn on from a high level input (rather than remote wire) so I need to know if I should cut into the cleaner signal before the OEM amp or just cut into the output from the OEM amp.
Cheers![]()
Yea that's pretty cool aye. I was looking a the new kicker amps and they can turn on by either hi/lo or remote wire. Nice gear coming out lately.
could have just played a 100Hz sinewave, and measured the voltage![]()
The stock amp is all still plugged in and it was 35c outside, asking on a forum in a comfortable 22c was easier![]()
