Results 1 to 12 of 12
Thread: Amp fuse blowing instantly
    VS
    Sep 2011
    Default Amp fuse blowing instantly
    Hey every one
    i have a jvc KS-AX3104 amp and a Pioneer GM-2200 amp. it all worked well after wiring up and testing it all, i unplugged it and neatened it all plugged it all back in.
    the fuse on the jvc blows instantly, and i cannot figure out why. i checked all the wires and they seem to be just fine. both amps are running of a power distribution block, and the main fuse is 60A and the other amp works just fine.
    cannot figure out what is going on.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Have you unplugged all the speakers powered by the jvc and powered it up?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    DId you disconnect the battery when you were putting the wires into the amp?
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    Jonah 101's Avatar
    Jonah 101 is offline I love photoshoppin
    vs executive Manual
    Jan 2012
    Tauranga
    I had the KS-AX3002 on a sub. It kept blowing fuses because the DVC sub was wired (4ohm) but we suspect it was a a bad sub because we put it on a bigger 760w amp and it went into protection mode so we wired it 2ohm and it was algood.
    IDk if any of this helps........
    My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
    VY S/II S Pack
    Apr 2011
    Unplug everything apart from the power wires and see if it works, if not you've screwed it (probably by shorting it).
    If it still works, gradually add one speaker, RCA etc. (while off, of course) back into the amp until you get another blown fuse. Vooooola, you have your culprit.
    VS
    Sep 2011
    there was at one point sparks when plugging in the power because my friend forgot to unplug the battery.
    i tryed it without the speaker wires, no luck. the fuse blows as soon as the battery is connected
    Is the amp dead?
    Jonah 101's Avatar
    vs executive Manual
    Jan 2012
    Tauranga
    There shouldnt be sparks from the power wire when wiring it unless the REM wire is wired up and the key is on.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I would venture that the amp is buggered than.
    I once tried to changed an amp fuse but forgot to unplug the battery. It sparked big time when the fuse made contact, but it blew all three fuses in the amp. Unplugged the battery, replaced all three and reattached battery, next minute boot was full of foul smelling smoke. Amp was fried. Also the smell lingers ####ing forever.
    Ronald Reagan (1986)
    VS
    Sep 2011
    Jonah 101's Avatar
    vs executive Manual
    Jan 2012
    Tauranga
    Whats it running, post make and model plus anything else you know, some of the boys here can tell ya whats up.
    VS
    Sep 2011
    i was trying to use it to power:
    2 140 Watt 3 Way kickers in the rear
    and
    2 180 Watt 2Way pioneers in the front
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by Jonah 101 View Post
    If the battery is hooked up when the positive wire is already in the amp and you plug the negative wire in, it will spark. If you do it in the reverse, it may spark. If you put the wires in the wrong holes it will spark like hell and fry the entire amp.
    Moral is: Leave battery disconnected (at least the negative terminal) until you have finished playing with it.
  1. Amp Fuse keeps blowing
    By Daan in forum Car Audio
    Last Post: 12-10-2011, 11:11 PM
  2. My fuse for the dash lights is blowing (number 1 - 15amp fuse)
    By aussie7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 06:10 PM
  3. Blowing fuse..
    By Lloydy1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2009, 09:16 AM
  4. My car keeps blowing fuse
    By bellasmummy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2008, 06:24 PM
  5. A/C blowing fuse VP
    By twasm6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2006, 07:29 PM
