hi guys will a 4inch speaker fit in the center of the dash in the 2010 sv6? cheers
You have posted this question already mate.\
To answer - don't bother, just disconnect it.
i ca get a pioneer for cheap so if i can il do it
A 4" speaker should fit but I would do a test fit if possible to make sure it will go in as you might need to slightly modify the housing where it will sit, I used a 4" Polk speaker and it was a tight squease to get it in.
