I was just wondering if you can run a sub and amp on a factory VY or VZ headunit??
Will it be easy to install?? And Will it sound as good as a after-market headunit??
Yea you can, just use a low level converter tapped into your speaker inputs or see asr audio and they can install proper RCA outputs on your stock headunit
Your sub amp will only play from a certain frequency, either set you by you or pre programmed so you can get some nice sounding bass in your vz
I have 1 llc in my ute which I then split the rcas and am running speakers and an amp off it, it goes pretty well, it sounds a little static when turned down but I think that's because my llc is right next to the h/u so I'm going to move it and see if it gets rid of the static
Last edited by SUP3RST4R_DJ; 07-02-2012 at 09:15 PM. Reason: Damn iPhone keypad lol
Thanks.. I just wanted to keep my stock headunit because it looks so much better then a after-market headunit
