Page 1 of 2 12 LastLast
Results 1 to 25 of 50
Like Tree2Likes
Thread: Farad Capacitors
    2004 VY S2 SV8 5.7
    Nov 2007
    Default Farad Capacitors
    Hey guys, Was thinking of Grabbing a Farad Capacitor for my car, Just wondered whether anyone has used Aerpro's or if its worth grabbing a Stinger or Rockford one?
    Was checking Ebay before and there not Badly Priced
    Cheers for the Comments and suggestions
    Regards
    Brendon
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    95 HSV Clubsport & 89 MX6 Turbo
    Sep 2008
    Demonicaland
    Waste of time. Capacitors are only a band aid solution if your having lights dimming issues etc.
    2004 VY S2 SV8 5.7
    Nov 2007
    Suggestions then for Fixing that Issue? Would it just be a Alternator Upgrade and Battery Upgrade?
    wraith's Avatar
    Sep 2008
    Demonicaland
    2004 VY S2 SV8 5.7
    Nov 2007
    Ok I have an Eclipse CD5030, 6" Soundstream SPL Splits and 5" SPL Splits in Rear, and 2 x 12" Phoenix Gold Ti12d4 Subs all running on a Soundstream Rubicon 404 and a Soundstream Rubicon 100
    wraith's Avatar
    Sep 2008
    Demonicaland
    What gauge wire are you running? The amp's are pretty average and shouldn't draw much by the looks of things.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It's just called a capacitor... Farad is how they are rated. 1 farad, 2 farad, 5 farad, 10 farad, 30 farad, etc.
    Make sure all your charging and ground wiring from alternator and battery are upgraded (which is what people call "the big 3") first. Then if your system is still drawing more than your alternator can provide (which I doubt it does) is the only time I'd consider a capacitor. I'd borrow one first to see if it is actually going to make a difference though.
    2004 VY S2 SV8 5.7
    Nov 2007
    Running 4 from battery to boot, and 4 into Sub amp and 8 into Speaker Amp..
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    And what are your grounds?
    You need to upgrade the positive wire from your battery to alternator, negative wire from battery to chassis and negative wire from engine block to chassis.
    Jonah 101's Avatar
    Jonah 101 is offline Undefined
    R32 Skyline
    Jan 2012
    Rotorua
    How can you tell if your charging system needs upgrading?
    I put a multimeter across my battery terminals and on a big bass drop it got as low as 12.6V
    My new whip - R32 Skyline
    My old ride-VS Commodore.
    wraith's Avatar
    Sep 2008
    Demonicaland
    Quote Originally Posted by Jonah 101 View Post
    Done the big 3 yet?
    Jonah 101's Avatar
    R32 Skyline
    Jan 2012
    Rotorua
    Quote Originally Posted by wraith View Post
    Done the big 3 yet?
    Nah not yet. Was thinking about going VT alternator if I did anything because they pump out 10amps more than the VS one.
    2004 VY S2 SV8 5.7
    Nov 2007
    Cool thanks for your Help. My Big 3 Being done on my Next Weekend Off and Will See how that Goes )
    Cheers For all your help, Will throw some Money towards Some Dynamat then to deaden some boot Rattles )
    Brendon.
    wraith's Avatar
    Sep 2008
    Demonicaland
    Waste of time. Go the big 3 upgrade first then go from there.
  15. #15
    Jonah 101's Avatar
    R32 Skyline
    Jan 2012
    Rotorua
  16. #16
    VT Berlina
    Apr 2011
    It's preferable to do the big three with 4 gauge or higher, with proper hex crimped copper lugs etc. Do it right the first time and you won't have an issue.
  17. #17
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Overkill is a good thing in this case guys, don't be afraid to go larger / as large as the budget permits, will save you from doing more upgrades down the track.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
  18. #18
    VL Wagon
    Aug 2010
    Adelaide, Australia
    that isn't low I have no doubt mines been in the 10's... but, ignorance is bliss...
  19. #19
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I'm going to go off-topic for a second here.
    I would like to say it is very refreshing to see someone post up model numbers of their gear when asked what they are running, and not Pioneer 500w, or Lanzer 10,000,000watt.
    So hats off too you OP.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    Now with my very own Tech2....YAY.
  20. #20
    wraith's Avatar
    Sep 2008
    Demonicaland
    Quote Originally Posted by acarmody View Post
    Agreed. Some one who has done their research first is always good.
  21. #21
    Jonah 101's Avatar
    R32 Skyline
    Jan 2012
    Rotorua
    Quote Originally Posted by AmmoJammo View Post
    Yeh I figured that it was fine seeing as my car wasn't running the battery flat but it pays to check. If the cars not running it can run the battery flat in about five minutes XD
  22. #22
    None - At the moment :)
    Dec 2005
    What setup have you got? Do the big 3 and go from there.
    +1 to first upgrading the “Big 3”.
    As said previously, caps are a band-aid solution. I think off the top of my head, the OEM grounds are 8 gauge...
    From the specs provided by the OP, 4 gauge would be the minimum sized wire you’d use (seeing the OP has used 4 gauge as the main power wiring, and hopefully the ground wire to the sub as well!).
    4 gauge costs roughly $9/m from Supercheap (Aeropro brand). Alternatively, you may have a meter or 2 of 4 gauge left over from your install. No harm in going 2 or 0 gauge; it will just cost more. You can grab 2 or 0 gauge from Jaycar.
    Also consider how you’ll be making the various connections: You may need to upgrade the battery terminals to accept 4/2/0 gauge...
  23. #23
    Jonah 101's Avatar
    R32 Skyline
    Jan 2012
    Rotorua
    I have seen at super cheap some battery clamps with holes and grub srew to secure the wire. I think I might do that. Dont think they are big enough for 2 or 0 gauge wire though lol
  24. #24
    '02 VU SS Series 2 5.7 6sp manual
    Dec 2011
    Kalgoorlie
    Jonah, my mate had those ones. They are crap. We were cruzing along doing 80kmh, wire came out, engine cut out and all electrics. Spend a bit more money on the battery clamp.
  25. #25
    Nic92's Avatar
    Nic92 is offline Rough As
    VY SS 5.7L
    Mar 2011
    WA
    maybe get something like this?
  1. Capacitors
    By nate-vy in forum Car Audio
    Last Post: 08-04-2011, 09:19 PM
  2. [VIC] SSL CAPACITORS - BRAND NEW. need gone today
    By fergie_vs in forum Parts And Other Items For Sale
    Last Post: 01-07-2010, 10:09 PM
  3. how many capacitors i need?
    By henrytad in forum Car Audio
    Last Post: 01-09-2009, 12:59 PM
  4. Capacitors, screens etc.
    By braaant in forum Car Audio
    Last Post: 10-02-2008, 08:19 PM
  5. What do capacitors do?
    By Evman in forum Car Audio
    Last Post: 23-07-2006, 08:09 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
