Results 1 to 16 of 16
Thread: Installing Rear 6x9's in VT
    Harro_vt Guest
    Angry Installing Rear 6x9's in VT
    Hey.
    This is my first post on this forum, and unfortuantly it's gotta be a question.
    Basically i just bought a VT II and i am installing rear 6x9's into it. I want to disconnect the rear door speakers and run the shelf speakers instead of them. But im having trouble getting the side trims off. ANy help mcuh appreciated
    VT2 Berlina
    Aug 2005
    Hi Harro_vt, welcome.
    Don't worry about starting with a question. I was the same, and probably most here.
    I have installed 6x9s in my VTII, as well as a head unit and front splits.
    Not sure why you want to disconnect the original rear speakers in the door. Do you plan to run wires from inside the door to the rear shelf? Are you keeping the stock head unit?
    I ran new wires from the shelf to the head unit. It's pretty straight forward.
    As for getting the door skins off, you need to pull the red insert out of the door lock. There is a thread here somewhere with some pics. Apparently you can gently ease them out without damaging them too much although I had no luck on the fronts, but was able to replace the speakers without taking the trim off in the end. Otherwise just jam a screwdriver through the middle of them and buy some new ones. If you have manual windows you will need to pull the winder off and of course any screws around the edge of the trim.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Harro_vt Guest
    Hey. THanks for that. But im also trying to get the plastic trims off the floor, between the carpet and bottom of the door.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    You need to prise the oval plastic strip and then underneath is some black screws that require a Torx Bit to remove.
    1998 vt Exec S1 3.8ecotec
    Nov 2004
    wallan
    i am wondering how you installed your 6*9's on the rear parcel shelfall i have are groves in the parcel shelf. are there holes under there to mount 6*9's
    Have a Good one
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    There is oval shaped metal plates spot welded into the parcel shelf, you just knock them out.
    Nov 2004
    wallan
    Thanks for the help soneX
    know i can get some 6*9's and hook up to my JBL amp. I just need to find some that can handle 104w RMS for each channel
    Have a Good one
    VT Executive S2
    Jun 2005
    Morayfield - QLD
    Post
    Quote Originally Posted by Ballport1998vt
    strathfield sell JBL 6x9's that are 100W rms. they go quite well (i have a set)
    EDIT: I think they sell for around $150
    scbh81's Avatar
    scbh81 is offline VRUUUM XU6 180 SC
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Quote Originally Posted by Muttley
    Sorry guys i have the same problem.. So what ur saying is that from the stock H/unit you could have all six speakers running from it? The front door, rear door and parcel shelf?
    There is no such thing as 'What if?'
    http://forums.justcommodores.com.au/...y-hsv-xu6.html
    Tasmaniak's Avatar
    car
    Apr 2005
    You can...but you shouldn't. Doing so will load down the HUs internal amplifiers pushing twice as much power out of it which will eventualy cause damage to the HU and speakers with all the distortion coming out of them.
    vt executive
    Feb 2009
    Default fitting 6 x 9 's in vt
    When fitting the speaker should i screw down through the speaker into the metal shelf? Or is it easier to go up through the bottom? Also is there a spacer ring of some sort that should go between the two surfaces to stop vibrations?
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Whenever I install 6x9's in a vt or vx, I attach the speaker to the metal in the shelf using self drilling screws or you can use wood screws (lol....trade secret)..... As for the grille on top depending on the model of car but most vt's and vx's didnt come factory with any speakers therefore you need to purchase the aftermarket speaker grilles they are in the same shape as the indent in the shelf, any car audio place will sell these....
    If you need anymore help feel free to ask.....
    cheers
    Lets work as a TEAM and do it MY WAY!!
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    how easy is it to replace 6 x 9s that are already in there, i didnt install them so i dont really know how they go in, and i guess i havent really had a proper look at them to figure them out. i got some cheapo DNA 6 x 9s put in there and they really suck lol
  15. #15
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The speaker screw holes should be in the same location, so remove speaker wires, undo screws, remove 6x9, put new 6x9 in, do up screws, connect speaker wires.... DONE.
  16. #16
    1998 VT 5LT CALAIS
    Aug 2008
    i replaced the 8"s that were in my parcel shelf recently. i put sony 6x9's in and they are xxxx... so much hassle for a worse sound. do i need an amp or something???
  1. VS Acclaim Rear 6X9's
    By Acclaimman in forum Car Audio
    Last Post: 03-05-2007, 06:25 PM
  2. Installing Flush 6x9's In VS Commodore
    By SidVicious in forum Car Audio
    Last Post: 03-12-2006, 01:04 PM
  3. Installing 6x9's in a VY?
    By Jake_king05 in forum Car Audio
    Last Post: 13-05-2006, 10:11 AM
  4. Replies: 16
    Last Post: 26-08-2005, 10:41 PM
  5. installing 6X9's in a vn
    By chevy_big_block_bro in forum Car Audio
    Last Post: 23-04-2004, 02:31 PM
