Results 1 to 8 of 8
Thread: Sub Problem
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    Default Sub Problem
    I recently bought the new JL audio sub 13.5" and will need 2 get a custom box made i have been quoted 170$ from (strathfield) and 240$ from (toweraudio) this is just for a box not ported or anything i was wondering if it was cheap or not or whether i can buy a 12" box and cut the hole bigger. will this give the same sound or decrease the subs performance?
    Sparkie Guest
    The size difference shouldnt matter its only 1.5 inches and you can buy a 12 inch box on e-bay for about $80. Unless you have a massive box you shouldnt port it anyway
    camvyss's Avatar
    camvyss is offline Doof, Doof, Doof
    VY2 SS 5.7L A4
    Sep 2005
    Really Rural Queensland
    A typical subwoofer enclosure (or box) is made to specific measurements provided by the manufacturer of the speaker in question. If you were to buy a box not specifically designed for your speakers then the chances of it being too big/small are large, not to mention your speakers might require a ported box.
    Now you could essentially obtain these same measurements and build your own enclosure. It would be cheaper in the long run but some wood working skill is required. If you are not happy to try that then really all you can do is outlay some money for what is in effect a good investment.
    Having an enclosure either too large or too small can damage your speakers and will definately impact it's performance.
    Dec 2005
    Western Suburbs
    for a full custom job its gonna cost around 600-700$$$$ (QUOTED BY)--- TOWER AUDIO--- but all i want is some bass nothing 2 fancy and i dont have that sort of money 2 spend ---- my friend has a 12" ported box from his sub we where gonna measure it exactly and cut and sand the hole bigger --do u think this is a good idea
    Sparkie Guest
    Your sub would have come with the demensions of the box needed.Compare this to a 12inch inclosure. I agree in full on compition gear it does matter but its 1.5 inches of difference i had to modify a 10inch box to fit a 12 inch sub in my boat cause its all that would fit and that runs just fine it depends what type of sound you are aming for
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    Joey_18 if the box is SEALED, you can do this with no problems at all. As long as the box is big enough (it probably is) then you can just shave a bit off the hole and make the 13.5 fit. With a sealed enclosure there are no real strict guidelines. If you want quick easy bass, buy a sealed box for $80 from JB hifi or any other car audio retailer and cut the hole bigger to make the 13.5 fit. Just make sure that you get a nice airtight seal around the woofer and that all screws will attach firmly and it's bound to give you great performance.
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    Dec 2005
    Western Suburbs
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    or simply build your own. look at the side of the box and see how much volume it needs and build it from there.
  1. Amp problem
    By Gunns VC in forum Car Audio
    Last Post: 16-10-2007, 03:33 AM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. Sub Or Amp problem???
    By calais_cruzin in forum Car Audio
    Last Post: 17-01-2007, 01:44 PM
  4. Another Problem
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2006, 01:03 PM
  5. Problem after problem!!!!!
    By Swerve103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2005, 06:24 PM
