Results 1 to 7 of 7
Thread: Help!!!!!
    Aug 2005
    Default Help!!!!!
    just bought new set of speakers for my vr commodore as a first timer at installing the speakers what will i need to do?
    Imports should be melted down cause they're shit.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    What speakers are they? For the front or the rear?
    Gravity is proof that nature keeps getting us down.
    Aug 2005
    there for the front and rear
    VY SS
    Aug 2004
    SE Victoria
    what size? if they are 6 inch they will fit nicely in both the front and rear.
    if they are 6.5 inch they will need spacers for the rear and the front door pods wil need to be cut or replaced with completely new custom pods for the speakers to fit.
    if the rears are 6x9s then again spacers will be needed.
    to fit the rears (if they are 6 inch) you just need to remove the grills and remove the old and screw in the new. if they are 6.5 or 6x9s then spacers out of MDF will need to be made and mounted on top of the exhisting holes on the chip board parsal shelf.
    the door skins will need to come off and again if they are 6 inch they will just slot straight in but if 6.5 inch then angles custom door pods will be the go. you can cut up the exhisting pods but it will not sound as good. i can post a couple of pictures of my MDF pods for the front and rear of my car that i made.
    also you can buy fiberglass mounts for the rear speakers but they are around 80-100. there is one last mounting option i have avioded mentioning because they are so damn ugly, they are small boxes for 6x9s that sit on the parsal shelf and look really bad and they cost around 100. enough said.
    any more questions ask away...........
    bns-sticky Guest
    Oh boy you are going trouble taking the door cards off if you dont know what you are doing.
    VY SS
    Aug 2004
    SE Victoria
    he has got to learn how to take the doors cards off some time . seriously though i know i have learnt all of the most useful things to do with cars by doing it myself.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Door cards arent that difficult, the only hard part is getting the window winders off and getting the vents out of the doors.
    Are the speakers splits or coaxials? It will be easier to install coax.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
