Results 1 to 3 of 3
Thread: VP Wagon Rear Wiring
    VB and VP
    Mar 2005
    Default VP Wagon Rear Wiring
    G'day all,
    Did the Executive come with wiring as standard in the rear of the car ? I cant see any but has what looks to be the option to put speakers in the rear.
    Anyone help ?
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    I don't know but if you put your multimeter on the terminal you found and set it to read below 20Volts AC then crank your headunit up. It should measure (and fluctuate) between 6-12Volts.
    VB and VP
    Mar 2005
    Thanks 12 Volt King,
    I found what the wires were for ... someone had a remote boot popper in there at one stage, hence no speaker wiring for the rear of the wagon.
    Ok; running the wiring is the easy part for me, BUT how do you pull the trimmings off from front to back so i can run some speaker wires ??
  1. vp wagon towbar and wiring questions
    By rileyp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2007, 11:23 AM
  2. Wiring diagram for VY berlina wagon
    By Loupy31 in forum Electrical Wiring / Questions
    Last Post: 23-04-2007, 01:23 PM
  3. VP Wagon Executive wiring
    By VB Owner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2006, 11:33 AM
  4. wiring schematics for VH Vacationer wagon..
    By ECILOPX in forum Electrical Wiring / Questions
    Last Post: 19-01-2006, 10:52 AM
  5. Sv6 rear speaker wiring
    By suppy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-09-2005, 10:15 PM
