Results 1 to 3 of 3
Thread: Alpine Subs
    VY Acclaim
    May 2005
    Glen Waverley
    Question Amp & sub power
    I'm currently investigating the purchase of a 10" sub and am interested in one of two Apline units. However I have two questions 1) is a 4 ohm or 2 ohm sub better/easier to power? and 2) what power amplifier would be needed to run the sub and the 4 other speakers.
    Both subs rate the handling power at 300RMS and 900-1000max. and would be in a sealed box.
    My ride is a VY Acclaim S/Wag with stock H/U. I've changed the front speakers to 6.5" 150watt splits and rears to 6" 150watt co-axial, and the sub/amp is next as soon as I get Phreddy to help me with the low output change.
    All answers welcomed.
    VY SS
    Aug 2004
    SE Victoria
    ok 1st one amp for the speakers and a seperate amp for the woofer is needed.
    a class ab 4 channel rated near your speakers should do. jaycar make a 4x50wrms and a 4x130wrms amps so that will cover most bases.
    2nd how many subs are you planning on? will you want more in the future?
    the jaycar 400wrms class d (monoblock) will power a 300wrms 4 ohm sub well with the sensitivity turned down a bit.
    to decide if you want a 2 or 4 ohm voice coil (VC) sub really depends on if you perfer choclate or vanilla icecream. the choice matters that much normally. eg if you have 2x 4 ohm woofers wired so that the load @ the amp is 2 ohm or you can have 2x 2 ohm woofers wired so that the load is 4 ohm at the amp.
    the main advantage of having a 2 ohm load presented to an amp is that it will almost double the amps output (with a small sacrifice in quality). providing your amp can handle a 2 ohm load. but remember that just because you speaker is rated to 300wrms or whatever having loss power doesnt really matter. doubling the power to a speaker only increases the volume a tiny bit.
    questions?
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    which alpine sub are you looking at?? My guess would be the sws-1042 and sws1022, type s. I think those are the numbers. If you're going to be running off an alpine amp, the 1042 would be better, as the 2 4ohm VC's can be placed in parallel to make a 2ohm load, perfect for alpine amps.
    If you are tossing up between these 2 subs, stop. Find yourself an amplifier first, and yoiu can tell us, and we can tell you which will best suit your amp. The reason these subs are made in 2 different VC configurations is so they cna be better matched to amps
  1. FS 2z Alpine ZR 12" subs
    By H00LiGaN in forum Parts And Other Items For Sale
    Last Post: 04-10-2006, 01:07 AM
  2. FS: Alpine Setup, 2 Subs, 2 Amps + Custom Enclosure
    By whisky in forum Parts And Other Items For Sale
    Last Post: 12-07-2006, 04:06 PM
  3. Alpine - 1 amp + 2 Subs
    By SMIT in forum Car Audio
    Last Post: 12-03-2006, 02:50 PM
  4. Alpine or pioneer subs??
    By Jarro_sparrow in forum Car Audio
    Last Post: 25-10-2005, 05:54 PM
  5. Alpine Subs/Amps
    By Bob129 in forum Car Audio
    Last Post: 18-03-2005, 01:55 PM
