Jordy93
I want to install a new system in my car, and understand the process as ive done it once before, and with the harnesses its straight forward, but just want some clarification as I'm not too sure on the rem wire. So i buy a new HU, i buy a harness to suit it, i buy a harness to match the cars wiring and i connect them together. But for my amp, after i run the rca cords, i have to run the rem/pwr.ant wire to it. I'm just confused with this as the vz has an electric antenna, and if i run the single rem/pwr.ant wire straight from the back of the HU to the amp instead of to the cars original wiring/harness will the antenna just stay down? I don't care for it to be hooked up just want to make sure that it stay unpowered
Thanks
Thanks
