Okay, so i've attempted to install 6x9's in my vz sv6... it all went pretty good... untill i tried to cut out the holes in board of the parcel tray to install the grilles! :b: i did the most terrible job... one of the grilles sits in okay.. but the other one i think i cut the hole slightly too big and it is just totally crap. im so dissapointed! did any of the vt-vz models come out with a parcel tray moulded board that has grilles built in? if so id love to hear about it... and where can i get one!???!?!?!
Drive it
Like ya stole it!
did you cut past the grooves that the grills fit into?
Matrix
Yes i did! I think i was in too much of a hurry...
any idea if the calais has grilles in the parcel shelf?
Drive it
Like ya stole it!
damn, i was worried about cuttign into my vl and you did it into your vz sv6 in a hurry. lol
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
Yes, as far as I know the Calais parcel shelf trim should have the grilles fitted. The Calais has the speakers there out of the factory, so....
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
NOW VE DASH LIGHTING CONVERSIONS!!
PLUS TECH2 DIAGNOSTIC SERVICES
JBL Car Audio dealer
awesome. now... i need to figure out how i am going to obtain one!
oh, and i love your dash illumination phreddy!
Drive it
Like ya stole it!
Thanks Jai!![]()
if all else fails, glue some tabs onto the speakers grille and then glue the tabs on underneath the parcel shelf.
I've done that for a few people who have stuffed up their own install.
I managed to purchase a calais shelf trim which i am yet to fit. Much releif!! Gotta love that stealthy factory look.![]()
Drive it
Like ya stole it!
Random curiosity, does the sv6 have wiring through to the parcel tray or do you have to splice off rear door speakers? in which case whats the best way to go about it?
Unfortunately no it doesn't have the wiring in place. The best bet is to run some cable from the rear door speaker wiring behind the B pillar trims. (can't remember the colours, sorry!)
Bear in mind that you'll have to disconnect the back door speakers though, 'coz otherwise you'll have too much load on the HU outputs - they can only run 4 ohm minimum impedance. If you hook up both the parcel shelf 6x9s and the door speakers, you'll be presenting a 2 ohm load, and the output chips won't handle it.
Cheerz!
or run an amp for the 6x9s they would sound alot better off an amp than the headunit. and just tune your rear door speakers to just be fill sound..
