Results 1 to 7 of 7
Thread: pioneer gear
    Pauly2478 Guest
    Smile pioneer gear
    first of all what does every one think of pioneer?
    and now for the question:
    i have a pioneer DEH-P4750MP headunit & a Pioneer 3100T amp.
    now the head unit has no subwoofer control!!!!
    and the amp only has a bass boost on the amp itself and no connection for one to plug into! what can i do?
    cause as is if i wanta turn bass up in sub it makes the speakers bass go up to, and thats not good.
    so please help (maybee sum 1 has same set up and knows how to tune it good?)
    please help :b:
    Pauly
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    If you bought the 5750MP, you would have got the extra RCA for subwoofer out Bass boost is not a way of turning your sub up, it only boosts a certain frequency range which isn't the whole range that your sub would be playing.
    Do you have an amp on your speakers?
    Pauly2478 Guest
    ok
    no amp on speakers
    what i mean is the sub is hooked up but the headunit has no sub control
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I don't have the 4750MP manual here but I just looked at the US model the 470MP and it says that you you can do the following: (Hopefully these two models are very similar)
    - Turn head unit off
    - Press and HOLD function button until the clock appears
    - Press function until "R-SP:FUL" appears.
    - You want to keep "R-SP:FUL", but you want to make "P/O:S/W". You change by pressing the side or up and down buttons. This is setting the internal amp to output full sound to the speakers and turning the subwoofer options on in the head unit.
    - Turn head unit on.
    - Go into AUDIO menu, go to the "NONFAD" option and turn it on.
    - Now you should have a "NONFAD:0" setting that you can press the up and down buttons to adjust the volume for the sub.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I just found out that your's has one RCA, the 470MP has 2 RCA's so your's probably won't have those options... If not, you can do the following...
    Put one of these in line with your RCA's. You will need to re-set your gains once you have though.
    Pauly2478 Guest
    so wot ur saying is because i dont have sub control on my headunit
    buy one of these thingys from jay car (and where else can u get them from)
    and then i can turn my sub up and down?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Yep.
    I don't know where else you'd get them, you'd have to ask at different stores.
  1. Redline 1st gear & 2nd gear...weird
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 09:02 PM
  2. WTB: Old Pioneer AV
    By breast69au in forum Swap / Wanted to Buy / Trade
    Last Post: 24-06-2006, 04:01 PM
  3. f/s pioneer
    By bjd in forum Car Audio
    Last Post: 04-05-2006, 06:45 PM
  4. 4th gear O/D 4th gear not working in vr
    By nathsvrbt1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 12:17 PM
  5. UK Top Gear and Fifth Gear Episodes
    By oblong in forum General
    Last Post: 25-02-2005, 09:34 AM
