the rear standard shelf speakers in my VZ Callais vibrate on base notes. Is there an easy holden fix for this or am I stuck with it?
check that they are not losse, if they are and u cant tighten them, pack something under them
the back speakers i believe are subwoofers in the parcel shelf on the calais. i have seen in the past when i worked at holden some clear plastic laying on / covering the cone of the speaker so when it hit base notes it would buzz / vibrate. had to pull rear seats out and parcelshelf to access it and just removed the plastic. being a vz will still be under warranty so take it back to dealer and get them to fix it for you!
yes it does sound more like a buzz, a vibrating buzz. I'll have Holden look at it for me on next service, thank you. I must admit so far it is the only warranty item on the list (touch wood).
