Hi,
Does any1 know how to remove the panel which covers the tweeters in a vz ss? Ive removed the air vent type thing on the end of the dash and found that 1 screw, but how does the rest come out?
Thanks.
i know there's a big difference between vz and vs...but on my car i took off the vent cover (like you said) and then the tweeters where held by a metal bracket to the dash,undo (i think it was two screws holding it) that and you've got the tweeter out.
dont know if that helps at all...
Once you have that air vent plate off and remove that one screw, the L shaped piece is only held in by 4 metal clips that are underneath the section. Now i cant stress to you more take your time and be very careful! The L shaped dash section should be able to be pried up, don't force it or pry it on an angle because these clips WILL break! Just work one clip at a time working from the outside to the center.
Hope this helps.
Jai
PS. I broke one of the clips on mine![]()
Drive it
Like ya stole it!
Thanks mate
