Results 1 to 24 of 24
Thread: Sub Box Sizing??
    Ute 04 VYIISS 5.7 M6
    Jan 2006
    Newman, WA
    Default Sub Box Sizing??
    Is there a rule of thumb for what size/volume the sub box has to be for the size of the sub.
    ie: 10" sub to suit a 27 to 30 liter box.
    Have done a goggle search "sub box size".
    Plenty of info.
    Did you build your box around the size of the sub or the other way around.
    VTII Acclaim
    Jul 2005
    NSW
    Try this: http://www.termpro.com/articles/buildbox.html
    Remember that all subs have a different optimum box. This means the volume and the type of box. Some only suit sealed, some only ported, other can be used in either type.
    Do you have a sub that you are trying to determine a size and type of box for? If so give us the brand and model and or the Thiele/Small specs for it and i'll suggest a type and size box that will suit.
    Cheers,
    JVC
    Focal
    JL Audio
    VDO Dayton
    Jaycar
    Dynamat Extreme/Dynaxorb
    Jan 2006
    Newman, WA
    Just making a general inquiry into it.
    Would like to build a sub box that would fit behind the seat's of a ute, VU/VY/VZ stile cab.
    I know that there is a lot of info on this.
    No real good pic's or info on the box sizing.
    Want to fit 2 x 10" sub's.
    One behind each seat.
    Just trying to get some info on the best size box and design.
    ____
    l........\
    l..........\
    l............\
    l_______l
    Guessing that this is the best shape suit to the cab.
    I'm not going to go the option of the box next to the fuel tank.
    VTII Acclaim
    Jul 2005
    NSW
    Measure the space and work out the available volume. Then, given a budget, we can suggest some subs that will work well in that size box.
    JVC
    Focal
    JL Audio
    VDO Dayton
    Jaycar
    Jan 2006
    Newman, WA
    Jun 2005
    theres a sub box calculator somewhere out there. i disagree with the 10 inch in a 27-30 litre box. My sub was designed to run best in a 26 litre box and its 12".
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Jan 2006
    Newman, WA
    That was a guesstimate, hence the ie
    Sorry to throw people off track.
    I think looking though some link's 27 to 30 L does a 15"
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Its really gonna depend on what sub you get. I think it might be pioneer that makes a sub designed to go well in a small enclosure?
    VTII Acclaim
    Jul 2005
    NSW
    Quote Originally Posted by phree
    Yep, different brands/models/sizes require different size boxes to work best. Next question.
    JVC
    Focal
    JL Audio
    VDO Dayton
    Jaycar
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    VTII Acclaim
    Jul 2005
    NSW
    Quote Originally Posted by semi
    was that last post aimed at me?? What question were you answering??
    No mate. Didn't see yours before i posted.
    There certainly are subs that suit small sealed boxes. Boston pro series come to mind, suit 0.5 cuft (14l) sealed boxes from memory and very nice SQ sub.
    Cheers.
    Jan 2006
    Newman, WA
    Jan 2006
    Newman, WA
    VX Calais
    Mar 2005
    try www.ajdesigner.com they have a couple of freeware designer program available for download depending on what type of box your trying to design
  15. #15
    Jan 2006
    Newman, WA
  16. #16
    VTII Acclaim
    Jul 2005
    NSW
    Quote Originally Posted by aperfectcircle
    Dame open office.
    Here wrong format.
    This is very small at about 13 litres gross, you will struggle to find a sub that will work to its potential in this. There probably is something though, perhaps a boston G210.
    This is more forgiving (about 23l gross), this would suit a JLAudio 10w3 or similar. Are you sure it will fit? Its a lot bigger than the other one.
    Anyway, now that you have found out the rough size of the available box, how much do you want to spend on the driver/s?
    Cheers,
    JVC
    Focal
    JL Audio
    VDO Dayton
    Jaycar
  17. #17
    Jan 2006
    Newman, WA
  18. #18
    Jan 2006
    Newman, WA
    We Have the following available
    UB8T
    8" Aerpro tube subwoofer with intergrated Amp
    - Remote bass boost volume control
    - In-built active amp allows for neat and easy installation
    - Wiring and mounting kit included
    - Enclosure volume (CubFt): 0.65
    - 250mmH x 250mmW x 585mmD
    - 80 Watt
    - Frequency 40-250Hz
    Barcode: 9317114892294
    We are currently developing a UTE BOX with buit in 12" Sub..... availably in April 2006
    Model Number UTEB12L
    Barcode 9317114894335
    Product Ute 12" 305mm Ported Subwoofer
    Description - Suitable for mounting between the seats
    - Sleek design for Utility's where space is scarce.
    - 12" 305mm Woffer with 40 Oz magnet
    - Maximum Power 500 Watts
    - Impedance 4 Ohms
    - Sensitivity 90 dB
    - Frequency response 30-1000 Hz
    - Volume 0.8 Cubic feet
    - 580mm H x 390mm W x 190mm D
    That's what i got when I asked-
    http://www.tdj.com.au/
  19. #19
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    just do the deed and go in through the fuel tank enclosure,
  20. #20
    Jan 2006
    Newman, WA
  21. #21
    Tasmaniak's Avatar
    car
    Apr 2005
    chicken.....
  22. #22
    Jan 2006
    Newman, WA
  23. #23
    VTII Acclaim
    Jul 2005
    NSW
    Everyone else seems to be happy with the fuel tank idea. Oh well it's good to be different i guess.
    Make your own. Bigger, better, badder than everyone else.
  24. #24
    VN Calais
    Feb 2006
    27 to 30L for a 15" sub? personally i wouldnt go for anything LESS than 55L for a 15" sub... but then again, im used to dealing with slightly different drivers to the average car sub.
    Adire Tempest... 200L tuned to 20Hz for a HT setup works quite well...
    Adire Tempest in a 55 - 65L box tuned to low 30's would probably work really well in a car. need to test that one day...
    -kRaZeD
  1. VY Injector sizing
    By fmlycar in forum V6 Development And Modification
    Last Post: 16-11-2007, 04:54 PM
  2. Help with Injector Sizing - Program I made
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2007, 11:32 AM
  3. Turbo sizing, t04/t3 hybride on a v6
    By cracker in forum V6 Development And Modification
    Last Post: 22-02-2007, 11:35 PM
  4. exhaust sizing for V6
    By immortality in forum V6 Development And Modification
    Last Post: 08-11-2006, 01:37 PM
  5. Wiring Sizing
    By AirStrike in forum Holden Commodore How-To's
    Last Post: 26-09-2006, 10:37 AM
