Results 1 to 5 of 5
Thread: unable to get 4 channels working
    vx-s_Man Guest
    Default unable to get 4 channels working
    i have a 4 channel pioneer amp and i can only manage to get 2 channels working. the amp is running off the stock vx head unit. ive installed the hi-lo converter to turn the wires into rca outlets.just wondering if i need two hi-lo converters to make 4 channels work. ive also tried splitter wires and they arent making the amp into the 4 channel.any help would be appreciated
    vx-s_Man Guest
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    i think there might be a switch or setting on the amp, depending on the model, to set the channels so that channels 1/3 runo off the 1 input ans 2/4 run off the 2 input, but im not sure if its there on pioneers. If not, buy some RCA Y-splitters and use them on your hi-lo converters, so that there are 4 RCA's running into the amp
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It probably has a 2 CHANNEL / 4 CHANNEL switch on the amp, as said above... Check that.
    VL
    Jul 2005
    SA, Mount Gambier
    yer or it may say INPUT A or A-B, them being the channels.
  1. AIR CON not working!!!!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2007, 03:50 PM
  2. S1 better for working
    By 38VNIT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2006, 08:56 PM
  3. window gutters / bailey channels
    By QNLOOK in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2006, 10:06 PM
  4. Splitting a low level audio signal to two channels?
    By DavidPartay in forum Car Audio
    Last Post: 20-09-2005, 05:15 PM
  5. VK Fan not working
    By Kevin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2005, 04:41 PM
