Results 1 to 5 of 5
Thread: eliminating engine noise
    vs v6
    Apr 2005
    Default eliminating engine noise
    hey guys im sorry this has probably been posted elsewhere but i cant find it. the problem is that when i go to power my rear 6 x 9 s off my amp i get the high pitched engine noise through the speakers consistent with the revs. i had cleaned the grounds / terminals i have no idea wats going on several of my mates are stumped to. has anyone had this problem or used a engine noise eliminator available from supercheap.
    cheers michael
    p.s have tried 3 diff amps same result
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Where did you run the RCA cables for the amp? Where did you run the power cable for the amp?
    Gravity is proof that nature keeps getting us down.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    vs v6
    Apr 2005
    kenwood deck, pioneer sub kenwood 6 x 9s i run my rcas from deck down left hand side and power from batt down right hand side no where near each other. the sound only comes in the rear 6 x 9s or wateva speakers i run of that signal out put of the amp. front ones are totally fine off amp. im so stumped.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Get yourself some in line filters. Make yourself a better earth and go from there.
    You can also get noise supressors for your alternator if the in line filters don't help.
  1. engine noise
    By reg9128 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2007, 05:45 PM
  2. engine noise!!!!
    By [SIK-GMH] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2006, 06:01 PM
  3. Help with engine noise
    By vl8 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-02-2006, 12:33 AM
  4. engine noise. need help
    By matrix in forum Car Audio
    Last Post: 15-11-2005, 11:06 PM
  5. Engine Noise....
    By stheggie in forum Car Audio
    Last Post: 30-04-2005, 12:39 AM
