Results 1 to 19 of 19
Thread: how long?
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Default how long?
    Hey just curious how many metres of power cable from Battery to boot,
    EG: Battery, through firewall, under door sil, up though into boot,
    How many metres?? 0 AWG
    MaT
    P.S- VN Commodore... I'm re-doing my install once again..
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    2008 VE SV6 Atomic Green w/ 20" Supersports
    Sep 2005
    Canberra ACT
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    I got six and I've got plenty spare. Five should do you fine.
    Gravity is proof that nature keeps getting us down.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    5m is too short for a commodore, been there done that(in VT sedan)... Extending 2ga is not an easy task... Blowtorch and welding gloves to hold the cable.
    6m is the safest option.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    yeh, too much is better than not enough, especially when you run it from front to back and it stops just that bit too short
    VT Executive S2
    Jun 2005
    Morayfield - QLD
    i think i got 8 or 9m when i did my VT. ran the cable all the way to the boot. had a bit extra. i ran my cable down the passenger side so it had to be a little longer.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    5m made it from the battery, throught clutch grommet, down right hand side sill, under rear seat and only just got through boot access hole... Not long enough to connect to anything in the boot.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    next question is why 0ga? Wank factor? C'mon dude, 0ga is for when you are running 4kwrms+
    An apprentice doesn't make that much
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Well,
    10" 3ways in front doors
    10" 3ways in parcel shelf
    2x12" Subs in boot
    1x10" Sub in boot
    Got another one of those amps on order.... Each of the 10" 3ways will be getting 380wrms each.... Gettind 2x800wrms Class D amps when i Get the subs....
    Sooo how many RMS did you say 12voltking....
    about 3000k RMS.....
    Is 0 gauge overkill???
    MaT
    gocommygo Guest
    nice setup im gettin 2 12' kenwood subs and an amp this pay to add to my 6x9's, HU and 3' speakers (all kenwwod)
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    errrr thats gonna be loud i reckon how r u fitting those speakers in the doors?? customs pods?
    Tasmaniak's Avatar
    car
    Apr 2005
    Quote Originally Posted by HoZy
    Well,
    2x12" Subs in boot
    1x10" Sub in boot
    MaT
    those 10"s are only rated at 100wrms. Not 380wrms Overkill no1
    fitting those speakers into the doors are going to make it illegal ( I know you don't care) but the other thing is...the doors don't have the cubic capacity to do those speakers justice. overkill no2
    You have nothing there for midranges. Just bass and treble. You've forgotten about the rest of the music. Overkill no3
    Plus, overall....it's gonna sound like butt and you will be the laughing stock amongst other car audio buffs. Have fun.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I'd have to agree with 12Voltking. You have no midrange and you're using different size subs which will sound like crap. Buy a good sub that can play the full range of subbass rather than 2 that are going to sound like crap.
    You definitely don't need 0ga wire. The 10" 3-ways will barely get over 100Wrms each (they won't handle anymore) and two Jaycar amps will be nearly 2000Wrms if you were playing constant bass.
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Ahh yeh I forgot to include I'm still keeping my Pioneer 6.5" Crossovers
    and 10" 3ways in front doors, not illegal if done correctly.
    MaT
  15. #15
    Tasmaniak's Avatar
    car
    Apr 2005
    still not going to need 0ga
  16. #16
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  17. #17
    EA falcon
    Jul 2005
    When I was putting my first stereo together, i had about 1000wrms of power. Regardless, i still ran 0gauge as i knew that i wanted to go crazy on the stereo later on down the track. (Never really got to that stage though as i moved away from the SPL scene and into SQ). My point is that if you beleive your gunna upgrade big time later on down the track, then i say go for it. If your gunna stick to what you've mentioned above, then it's not necessary.
    And as for your speaker setup..... [copy past 12voltking and stoneX's posts]. :P
  18. #18
    mouce's Avatar
    Jul 2005
    Planing for future upgrades makes sense, I ended up getting a fairly chunky cable for mine and it's going to be about 1100wrms. The cable is a 50mm2 cross-section which I think is somewhere between 1ga and 0ga. It's actually the power cable used in arc welders (I could get it damn cheap).
    It's massive overkill for this installation, but further down the track...
  19. #19
    Toyota Landcruiser
    Oct 2005
    Central QLD
    Bout as long as a piece of string.
    Bring all coalition troops home from Iraq before Christmas, and stop the senseless killing.
  1. How long will you keep your car????
    By AttaBoy in forum The Pub
    Last Post: 09-03-2007, 05:23 PM
  2. how long
    By vq_statss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 09:03 PM
  3. Vt long trip
    By vt_lover in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2006, 01:50 AM
  4. how long will it last
    By mutant in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-02-2006, 02:56 AM
  5. How Long Does It Take !!! ?
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2006, 08:42 PM
