Results 1 to 7 of 7
Thread: Reception Funness
    '00 WH V6
    Dec 2005
    Default Reception Funness
    Howdy.. I just noticed this earlier tonight when I was washing the VS..
    I had the antenna totally down (it's not electric) while i was washing, which is why i probably noticed it more.
    When the car was just switched to accessory, to have the radio on, it all sounded fine, reception was good. When I turned the car on to drive off (antenna still down) the reception went totally to crap. Is this a sign of bad earthing? It's just the stock HU (will be changed in a week or so).
    If it's just the way it is, that's cool, but it would be nice to know if it's something I could easily fix.
    Driving a CURSED WH V6.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    No, it would most likely be a sign of interference from the electronics running the engine. Does it work fine with the antenna up?
    I'd say it's just because with it down you're getting a weaker signal, so the electrical noise from the engine running is more apparent.
    '00 WH V6
    Dec 2005
    Yeah it was better with the antenna up, not as good as down with the engine off though.
    If that's just how it is.. no worries at all, just wondering if there was an easy fix (ie tracing earth wire and re-earthing a bit better)
    DJ Majah's Avatar
    DJ Majah is offline Electro doof doof styleé
    VSII cruiser
    Jan 2004
    Brisbane - Ipswich
    Theyre all the same, I had a Magna and the reception was great, then I got my Commie and in the same places it was shit.
    So I replaced it with an electric one
    Queensland - The Cruising State
    '00 WH V6
    Dec 2005
    DJ Majah's Avatar
    VSII cruiser
    Jan 2004
    Brisbane - Ipswich
    Yup, its bigger!
    Probably less rusted too, those original ones are cheap.
    '00 WH V6
    Dec 2005
    Mmmmm.. need to add it too my ever expanding shopping list then ...
    Cheers for the help.
  1. FM Radio Reception
    By Wokka in forum Car Audio
    Last Post: 25-08-2006, 12:16 PM
  2. radio reception??
    By quiksilver1 in forum Car Audio
    Last Post: 04-06-2006, 01:21 PM
  3. crappy radio reception
    By jams351 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-12-2005, 09:46 PM
  4. '00 Barina radio reception
    By kaycee in forum Car Audio
    Last Post: 02-12-2005, 01:59 AM
