Results 1 to 11 of 11
Thread: Remote Wire Connection
    VS Acclaim S2
    Nov 2005
    Default Remote Wire Connection
    Hey all, back again for another exciting episode of "so what on earth do i do now?"
    Here's my problem... I have a Sony headunit (no that's not the problem although some might beg to argue) and on this sony headunit i need to run a wire from the remote terminal to switch on my amplifier when the headunit is on... I've bought myself an amplifier wiring kit... in this i have one long thin piece of cable which is the remote wire. Now i've asked others about it, and everyone i've talked to has has a small piece of wire already coming from the remote spot on their H/U which they then simply crimped or soldered to their remote wire and ran it through to the amp.
    HOWEVER, on my headunit, the place where i am supposed to be connecting my remote wire to does not have wire already extending from the headunit, but rather has what appears to be a small plug/sockety thing. It almost looks a bit like a headphone spot on a walkman where you would plug your headphones into. (Yes, this is definitely the remote spot on the headunit and not for any other sort of input or output). I was wondering if anyone else has had a similar headunit and whether you can buy some sort of jack like connection that is made for it or something...
    Any help much appreciated, thanks all.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    hmm, is it a bullet terminal maybe? otherwise, is it just the one wire with a connector on it or multiple wires to that connector? if its one wire, cut it off and crimp your remote wire on.
    VS Acclaim S2
    Nov 2005
    hhmm nah i mean like there's physically no wire coming from the H/U remote spot... it's just a plug hole thing... like if you can picture a powerpoint on a wall... and you plug say a toaster into it... the remote spot on my H/U is like that in the sense that something has to plug into it.
    Have a look at the diagram i've attached, it should show you what i mean a little clearer hopefully.
    Attached Thumbnails Attached Thumbnails Remote Wire Connection-headunit_remote_question.gif
    hakhawk's Avatar
    Jan 2005
    DJ Majah's Avatar
    DJ Majah is offline Electro doof doof styleé
    VSII cruiser
    Jan 2004
    Brisbane - Ipswich
    You arent confusing the remote power (generally yellow cable) - which you are looking for to turn other devices on, with a remote port - for a remote control (infra red, or on steering wheel)??
    Queensland - The Cruising State
    MoSkA's Avatar
    MoSkA is offline Steriotypical Wog
    1998 Subaru WRX
    Jan 2005
    Yeah there should be a wire coming out with Earth, 12v, Accessory, Speakers, etc. on the same connection. Mine's solid blue, but mine's also Pioneer.
    I don't use windscreen wipers, i just use the superior handling of the STI to dodge the rain drops.
    bbad13 is offline bbad13
    VZ Exec. Wagon
    Mar 2006
    Yorketown s.a.
    Quote Originally Posted by Brycestro
    is that where the antenna gets pluged into???????
    jack.mc's Avatar
    jack.mc is offline Nothing witty to say :(
    VN Vacationer
    May 2005
    Sydney, NSW
    Quote Originally Posted by bbad13
    thats what i thought when i saw the pic...
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Brycestro, it may also be called the ant(+) or trigger or rem(+) or somehthing similar. we really need to konw the model number of the headunit.
    VS Acclaim S2
    Nov 2005
    Ok... rechecked instruction manual... it refered to an optional steering wheel control attachment as the "remote" wire and hence the confusion. I have now found the wire i was chasing though and it's connected. Apologies to all those whose time i've wasted here
    hakhawk's Avatar
    Jan 2005
    no problem mate, glad you got it sorted. we all gotta learn somewhere.
  1. can i run a remote wire of another remote wire
    By Burnout_bro in forum Car Audio
    Last Post: 07-05-2007, 11:16 AM
  2. Remote wire
    By [NatHAn] in forum Car Audio
    Last Post: 15-04-2007, 02:46 PM
  3. wire connection
    By dijm8 in forum Electrical Wiring / Questions
    Last Post: 09-03-2007, 11:14 PM
  4. remote wire on pionner DEH-P1Y
    By beefcream in forum Car Audio
    Last Post: 28-04-2006, 01:41 PM
  5. Amp remote wire
    By yogi_6_9 in forum Car Audio
    Last Post: 19-01-2006, 01:41 AM
