Results 1 to 2 of 2
Thread: Speaker Hissing
    Red_dwarf10 Guest
    Default Speaker Hissing
    Hey i just put in splits in my car and an amp and it was working fine for a few hours until i started getting i high pitched hissing which incresed as i accelerated. it sorta comes on and off every 20 min or so. i've been told it's to do with eather the alternator interfering or the position of the crossover for the splits being so close to the electronics. i'ts really frustrating so any help would be great plz.
    cheers
    VN SS
    Mar 2006
    Hey there, it may be a variety of things causing your "hissing" noise. It may be engine interference as you have been told or yes, electrical interference, if you are running an amp it is of utmost importance to note that your RCA cables are not running with your power cables.They must not run together as this causes interference. You can buy noise suppressors that should eliminate any problems you have with hissing due to engine interference. These are available at most electronics stores and your usual car accessories outlets.
    Hope this helps ya.
  1. hissing noise
    By peter048 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2007, 07:02 PM
  2. Gen 3 V8 hissing noise
    By bails in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 03:39 PM
  3. Air Con Hot and Hissing me off
    By Bradles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2006, 12:50 PM
  4. hissing VL
    By livenletspool in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-06-2004, 11:10 PM
