hey guys, 2day i bought sum 2nd hand subs in box and amp +other stuff off another jc member actually.
well jst wanted to show u wat i got and sum tips of puttin it all together and if i need anything else cuz i kno basically nuttin with this stuff so ne help wud b appreciated.
The gear: 4x10" pioneer sub in box, amp is impulse kicker, other stuff is jst the cable and a few neons with transformers.
-the box jst fits on the hump in the boot with the perspex window facing towards the front, with like 3mm clearance on each side so its a perfect fit but will need sum feet(70x35mm pine will do) for the front cuz it sticks out where the hump ends.
skylines are like tampons...every c*#t has got 'em...lol
Mt. Nebo Easter 2006 Cruise:
- Bogan Award
- Stock Award......
thats some nice gear you have should sound good once its up and running
All i can say is make sure you have good earths for the amp as in run back to battery or to chassis (subframe)
