Hey guys I have recently installed a new DEH P1Y 60w x4 and 3 rca pre outs. I have run all the rcas,
My setup DEH P1Y,weconic 4 channel,2channel 222w sony, pioneer bullet splitz,pioneer 5way 6 x 9's.
i have an issue i get a frequency interfernce noise on the 6 x9's which is on 2 of the high pass filter channels of the weconic 4 channel.Also can here interference when i click the indicators?
may this be rca's even tho i have swaped them or bad earth some where on the car or the new deck? I am confusedis there a fix for this ?
Cheers.![]()
* RVN 355 *
hmm, yeh, id check the earths, and possibly, are you running the amp power wire next to rcas? if so, move it, rca's and speaker wire on one side of car, power on other.
they are not together cheersOriginally Posted by hakhawk
Cheers.![]()
* RVN 355 *
ok, then bad earths, bad connections, umm, alternator noise suppressor thingy
thanks bro ill check that out b4 i start gettin it 2 get pro jobOriginally Posted by StoneX
Cheers.![]()
* RVN 355 *
Do you know how to check it out? The fuse is internal. You need to remove the head unit and use a multimeter to check the continuity from the RCA ground, which is the outer ring, to the chassis of the head unit as that is ground too.
If there is no continuity the internal fuse is dead.
Everything seems fine, removed the new deck and put my old one back in no dramas everything is fine the noise is only one the new deck on rear rca's. Swaped amps and rca's as well same problem...Originally Posted by StoneX
Going to take back the deck back to mora afta work to the shop to see if it is faulty or whether i should get a noise filter $50 tho damn! I need this fix to beats damn really sucks.
Cheers.![]()
* RVN 355 *
Don't waste money on a noise filter... If you have noise something is not wired correctly. It's best to fix the problem than to hide it.
problem was the deck. Took it back swaped it and re wired everthing and no drams sounds good look nice and performs the way i wanted it to be PIONEER DEH -P1Y 60W X 4.... THANKS GUYS
Cheers.![]()
* RVN 355 *
