Results 1 to 3 of 3
Thread: Speaker wiring to amp
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Default Speaker wiring to amp
    Ok, you sound guru/professionals are probably gonna slap me for what im about to say, but screw it..
    I aquired me a pair of BOSS 10" 500W subs, accompanied with a 750/780W "Deathwish" Amp
    The amp only has a positive and negative for left and right channel (two channel bridgeable).
    I wired each 10" to a channel each, and my 12" Clarion 600W Sub to be bridged. That worked fine and dandy (consulted existing owner, he said it'd go well).
    I had to remove the 2 10" subs to have some bootspace, bridged the 12" on it's own - no bass.
    From now on all I get is 2 10" subs, can NOT for the life of me figure it out, any solutions?
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Boss & Deathwish! Could be your first problems.....
    Secondly could of blown something internally, not meant to run subs off each channel then bridge, you'll overheat your amp guranteed...
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It's called tri-mode, alot of amps allow wiring like that.
    Can't tell you what's wrong though.
  1. Front speaker wiring in VS
    By shooter18 in forum Car Audio
    Last Post: 27-04-2007, 05:29 PM
  2. VN Rear Speaker Wiring
    By Rustyone in forum Car Audio
    Last Post: 02-10-2006, 11:16 PM
  3. vt door speaker wiring.
    By ciaranvt in forum Car Audio
    Last Post: 12-01-2006, 09:43 AM
  4. pioneer HU speaker wiring
    By vh-holden in forum Car Audio
    Last Post: 16-12-2005, 04:28 PM
  5. Speaker Wiring Help
    By mk3_1 in forum Car Audio
    Last Post: 19-06-2005, 02:51 PM
