Results 1 to 6 of 6
Thread: head unit problems in vl
    vr commodore
    Apr 2005
    brisbane QLD
    Default head unit problems in vl
    just wired a sound system with my mate who owns a vl and we have used the standard power wires for the head unit but when we turn the headlights on everything shuts down, without headlights if we turn the music right up it turns itself off and then on again
    ne one with ne sorta advice muchly appreciated
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Not sure about the headlight prob but did you use the earth wire from the stock HU? If you did you need to earth the new HU directly to the chassis.. this will fix the turning on/off prob when you crank it.
    Check out Head Unit Cut Outs? for a few notes and tips on how to do it
    vr commodore
    Apr 2005
    brisbane QLD
    91 VN SS 355
    Feb 2005
    WEST SUBS
    run a new feed, sometimes earthing or too much draw may cause a interference with your lights im guessing there on the same circuit or someting is touching. Try a new feed and ground point that may help you
    Cheers.
    * RVN 355 *
    vr commodore
    Apr 2005
    brisbane QLD
    thanx we end up disconnecting the cigarette lighter and runnin the active and earth of of that so the whole time the two probs were caused by a bad earth thanx for ur help
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    yes, you could say it was a bad earth.. the earth issue being the fact that it was actually an llumination wire. When you switched on your headlights the earth wire suddenly became an active 12Volts wire
  1. VE Head unit in a VZ??
    By scottishgit in forum Car Audio
    Last Post: 19-10-2006, 01:19 PM
  2. Head Unit Problems- Just a blown fuse?
    By RedLiner in forum Car Audio
    Last Post: 31-05-2006, 09:33 PM
  3. Head unit problems :(
    By COINERS in forum Car Audio
    Last Post: 30-05-2006, 07:10 PM
  4. vt head unit
    By clinker42 in forum Car Audio
    Last Post: 21-07-2005, 01:21 PM
  5. EFI unit Head on Red 202
    By cyberjo in forum Straight 6 Development And Modification
    Last Post: 05-04-2005, 08:40 PM
