Results 1 to 3 of 3
Thread: VP new install
    VT Berlina
    Mar 2006
    Default VP new install
    just bought a total kit,
    explode 12" sub
    explodes splits
    panasonic CQ-C5401W head
    audiolinie 800w mono
    audio 800w 4 ch
    no idea how to install, been reading this site all night, i have got the whole idea of connecting the amp power cords and such to the bat and thur the firewall down pat, but whats the go with the fuse block and what connects into it and out? it says something about having it as close to the bat as possible, but i am not sure what to do, i dont cut my power cable or anything do i?? i am going to power all four speakers thur the amp, so i just run a set of rca cables to both amps and then what wires go from the speakers to the amp?? the guy at audiobarn said i didnt need anymore cables or anything, or should i have gotten speaker wire?? or do i use whats already on the speaker and try and get it to reach the amp? or do i just add more wires to the termanials and run that to the amp as well??
    also, the rca cables, they run down the back of the head unit and how do i get them to the back of the car? under the console or something? and what do i have to take off to put the rca cables thur so i can run them to the back? i presume get them out from under the middle somehow and then run them down under the skid guards on the doors?
    Thanks any advice would be apperciated
    VT Berlina
    Mar 2006
    ah brainwave, the fuse spilter is connected to the power cable from the battery, and then i should have two short thick power leads one to the mono and one to the 4 channel?? but then where does the ground cable connect to?
    VT Berlina
    Mar 2006
    all installed, took 6 hours but all sweet, except having problems fitting the deck back in flush, hopefully having the right angled rca cables at the back of the deck will help
  1. CRS kit install help
    By PerceptionTwin in forum V6 Development And Modification
    Last Post: 01-02-2011, 10:17 PM
  2. VN Install
    By draco386 in forum Car Audio
    Last Post: 05-11-2007, 01:20 PM
  3. VZ Install
    By SV6 in forum Car Audio
    Last Post: 12-02-2006, 04:25 PM
  4. New 4ch amp install
    By killuminati in forum Car Audio
    Last Post: 04-12-2005, 01:18 PM
  5. how to install ac in a VL
    By gambit120 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-10-2004, 11:36 PM
