Results 1 to 6 of 6
Thread: capacitor probs
    vh commodore sl
    Jan 2006
    Unhappy capacitor probs
    i have a BLITZ 3 FARAD capacitor and i recently rewired my stereo and after disconnecting the capacitor it went flat and i forget how to charge it to use it again.its plugged in and is running power through coz it has a completed curcuit but it dulls in and out and no display so its not charged to work what do i do??????????
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    to charge mine it just needed to be all wired up and have power (eg accesories on or car running etc) Make sure u have a good earth on it and make sure ur remote wire is conneted/working
    vh commodore sl
    Jan 2006
    Default :)
    ill try changing the earth.........if it hasnt got a good earth would it still be letting it play coz it all works its just bypassing through capacitor which isnt on or coz its doing that does it mean the earth is ok
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Hey Guys.
    Charging a capacitor is as simple as connecting it directly across the battery supply line - "+" to positive, "-" to negative. (and don't connect it the wrong way around or disaster awaits!!! You could also be seriously injured if the cap explodes - which they certainly can do when reverse voltage is applied)
    The tricky part about charging such a large capacitor is that because the "in-rush current" is quite high, you can get a healthy spark when the voltage is first applied.
    Operationally the capacitor just sits across the main battery supply to the amp - that is, one terminal to positive and the other to ground. The positive lead then extends a little further to the amp. You can use the same earth point for the amp and the cap, but you don't have to.
    What might be happening here is that your amp has a good earth, 'coz it seems to be working OK, but maybe the cap's earth is a bit bodgey. Alternatively, the capacitor itself might be working fine, but the voltage display circuit might be stuffed!!
    BigDaz - not a bad suggestion, but the remote line won't have to be high to charge the cap - it's supposed to sit across the full-time +12 supply anyhow.
    Anyhow, hope it helps.
    Cheerz!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Shine a light at it
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    LOL!!!
    Yeah, that was a good one, huh 12V?
  1. FS: 2 Fusion SUBs in box, Fusion amp, Fusion Capacitor
    By BigDaz in forum Parts And Other Items For Sale
    Last Post: 08-03-2007, 04:48 PM
  2. Capacitor Wiring Help!!??
    By Troyziee in forum Electrical Wiring / Questions
    Last Post: 08-12-2006, 02:43 PM
  3. Capacitor Wiring Question.
    By Wagon_Wheel in forum Car Audio
    Last Post: 04-12-2006, 01:57 AM
  4. VS probs
    By VScom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2005, 09:57 PM
  5. vq probs
    By Tigress in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2004, 11:43 PM
