hi all, i have had my stereo wired up for a while now and its been great. I just had some more stuff put in and it has increased the amount of amps that the system draws. I have a 100amp circuit breaker inline with my 4guage power cable, before the new set up i had to push realy hard to trip the breaker. Now with the new gear (which was installed by "pros" this time) i can trip the breaker a lot easier. My first thought was to just get a bigger breaker or fuse (not too worried which kind) say about 150amps worth, which should take care of the problem.
But, after reading a post which spoke about "amp ratings" on power cables. So i checked it out and the 4g cable installed is only rated to 110amps.
I looked around and there are heeps of different kinds of 4g cables with different fuse ratings....
i dont want to have to rewire the whole car but if i have to then i have to, i dont want some kind of melt down to happen.
So, what i need to know is how much can this cable actualy take and would it be dangerous to use it with a 150amp fuse since it wont register until it hits that point.
any and all advice would be apreciated.
Matrix
The cable may be able to handle 150 amps (I dunno) but get a bit warm. The thing you would have to watch is that when a conductor heats up, its resistance increases. The wire would probably need to get fairly hot before the insulation would melt, but you may end up seeing a noticeable voltage drop. I’m not sure on the exact figures and that so if someone could enlighten me that would be cool.
thanks Dephilile, electricity makes me nevous- i think i might rewire it, just to be sure...
Matrix
Throw a length of 2ga from battery to boot, and run a distribution block with the 2ga coming in, and 4ga to each of the amps. 2ga should be plenty.
Gravity is proof that nature keeps getting us down.
why would i need 2g cable? and who says the 2g stuff wouldnt be only 120amps? i have found 4g cable that has a 220amp rating which would mean i can leave all the fitthings the same just change the wire over.
its not the size of the cable but what it can handle that counts.....
Matrix
Actually the size of the cable has a hell of a lot more to do with it than the 'rating' that the manufacturer stamps on it.
I'd be worried about the length of the cable you're using, I can get an 8ga cable to drag 400A if it's only an inch long! But if you're looking at about 5 or 6 meters of cable you're going to need to get something a LOT thicker.
most 2ga handles a rated 160amps. just change the cable and think of all the extra possibilities of having a larger power cable........?Originally Posted by matrix
